Ring group only 1 out of 2 ringing
Discussion in '3CX Phone System - General' started by Resolve, Feb 29, 2008.
  1. Resolve
    Sep 19, 2007
    94
    Ring group of 2 phones - when set to "hunt" both phones ring in turn as expected. When set to "ring all" only one (always the same) rings.... :?:
    Linksys 942 phones. Version5.1.4128.0 of 3cx
    Tim
  2. josvic
    Apr 24, 2007
    51
    I have the same scenario, with 3 softphone... but all OK.
    Have u tried with softphone...?
  3. Resolve
    Sep 19, 2007
    94
    No I haven't - that's a good idea.
    I seem to be finding more and more now that the problem stem in some way from the Linksys 941/942 phone. I'm going to take in a Snom320 as a swap in to try that too..
    Tim
  4. josvic
    Apr 24, 2007
    51
    Post your results to the forum... Thanks...
  5. Resolve
    Sep 19, 2007
    94
    After replacing some kit (router - to solve a different problem) and restarting everything, the problem has cured itself.
    I'm sure we tried this before but...perhaps I'm losing it ! :shock:
    Tim
  6. josvic
    Apr 24, 2007
    51
    Maybe it was your router port routing problem, strange thing... Hoppeless your problems are going away...
    Regards.
