Ring Group Pickup (Bug)
Discussion in '3CX Phone System - General' started by cloidhamer, Dec 7, 2010.
  1. cloidhamer
    Jan 30, 2009
    27
    After upgrading to Version 9 my two receptionists are having an issue where if they answer a call into the Ring Group at the same time the 3CX server connects their extensions and drops the incoming caller. Sorry I don't have a log to post yet as I have just been made aware of the issue. I wanted to see if anyone else had seen this issue. We are using Snom 320 phones. Thanks.
    Craig
  2. mfm
    mfm Active Member
    Mar 4, 2010
    641
    It would be ideal if you could get the logs, also what version of 3cx are you running?
  3. cloidhamer
    Jan 30, 2009
    27
    Here is a log from a call that was mishandled. I called into my office from my cell phone. When ext 100 and ext 110 picked up the assistant showed that ext 100 had the call, but there was no audio either way. Thanks for any help on this.
    Craig
  4. mfm
    mfm Active Member
    Mar 4, 2010
    641
    Hi Cloid,
    Cant pick up much from the logs unfortunately, it would need so more in depth analysis.. do you by any chance have a support contract?
  5. cloidhamer
    Jan 30, 2009
    27
    Sorry, I do not have a support contract.
    It seems that it is a software bug since I had no issue while on version 8 and now that I have upgraded to 9 it is present.
  6. mfm
    mfm Active Member
    Mar 4, 2010
    641
    We haven't had similar reports, did you install service pack 5 and see if it helps the situation although I strongly doubt its a bug. Normally in such cases there is an incorrect exchange of IP's but for audio to be dead both ways is a little strange. Make sure your PBX is in sunless mode.
