Ring Group Problem
Discussion in '3CX Phone System - General' started by Massimo Tribolati, Jun 21, 2017.
Tags:
  1. Massimo Tribolati
    Jun 21, 2017
    6
    Hi all,
    I've got a problem with ring groups in last version of 3cx.
    This is the scenario: I would like that any incoming call will be routed, first of all, to a single extension (lobby) and, in case of no response in 30 seconds, all the other extensions had to ring.
    So I've created 2 ring groups:
    - Ring Group 80 that contains only extension 61
    - Ring Group 81 that contains ALL the other extensions EXCEPT 61 (62, 63, 64, 65, 66 and 67)
    RG 80 is configured that, in case of no response, the call has to be passed to RG 81.
    The problem is that, when a call arrives, all the extensions start to ring. After 30 seconds, extension 61 stops to ring and the other continue.
    Seems like the RG 80 has all the extensions but is not like this!
    Anyone can help me?
    Massimo
  2. daktur
    daktur New Member
    Oct 15, 2015
    225
    7
    @Massimo Tribolati ,
    Instead of using a ring group for only one extension should select the did to ring only 61 and if no answer / busy (according to.your need) forward the call to ring group 81 where extension 61 is not listed.
    Good luck
  3. Massimo Tribolati
    Jun 21, 2017
    6
    Hi Daktur and thank you for your time.
    I've followed your idea but the problem still remains identical.
  4. pact
    pact New Member
    Dec 16, 2009
    172
    31
    Hi Massimo,
    Are you able to post screenshots of your two ring group configurations?
  5. leejor
    10,371
    230
    If you are sending the call only to Ext 61 and the others are ringing at the same time BEFORE you have specified that the call forward on to that ring-group, then , check the 3CX Activity Log (right after one of these calls) for the reason, for this behaviour. You must have something else set, that will explain this.
  6. Massimo Tribolati
    Jun 21, 2017
    6
    Hi pact,
    here are the printscreen.
    Now I've changed the configuration following daktur advice, so I've got only 1 ring group. The problem is still the same.
  7. Massimo Tribolati
    Jun 21, 2017
    6
    Hi leenor,
    checking the activity log what happens is that both Ext. 61 and RG 81 are called together.
  8. leejor
    10,371
    230
    A single Extension (not part of a ring group) and a ring group will not simultaneously ring unless you have routed the calls to them, somewhere. DID routing? Go back and check all of the "rules" you have created.
  9. daktur
    daktur New Member
    Oct 15, 2015
    225
    7
    @Massimo Tribolati
    After reviewing your screen shot seem the DID is not properly configured and that what is causing the problem.
    Try setting the DID as *75609131 and it think the issue should be solved other than that, when other extensions, not 61, ring do you see the ring group showing on the screen? If not it means they are ringing individually and not through the group.
    Hope you can solve it !
  10. Massimo Tribolati
    Jun 21, 2017
    6
    The only DID i've created is the one I've posted
  11. Massimo Tribolati
    Jun 21, 2017
    6
    On the screen I see the caller id, not the Ring Group ID.
    How I have to set the DID as *75609131? I've set in SIP TRUNK as you can see in the attachment, but that doesn't resolved the issue.
  12. daktur
    daktur New Member
    Oct 15, 2015
    225
    7
    Now you have to reconfigure the DID to ring only in extension 61 and the other configuration should remain the same.
    It should work now, if you have any further questions you can send me an inbox :)
