- Joined
- Mar 25, 2009
- Messages
- 12
- Reaction score
- 0
I need some help setting up a ring group, or at least I think thats what I need. I am using 3CX to basically route calls to my field techs and we aren't using any physical phones (they are unregistered under each extension but thats ok for now). So each extension is configured with a Ring Group with only one user as a member in which the number auto forwards to an external number. I had to do it this way because Vonage does not allow using the "Forward to External Number" option on the Forwarding tab but for some reason it works when you do this with a Ring Group. Long story short I have two extensions that I would like to do this behavior with to multiple external numbers. Is there a way to do this using the Ring Group "Forward to External Number option" with multiple numbers?
Joe
Joe
