ring group version v3.1.2434 not possible
Discussion in '3CX Phone System - General' started by clavaud, Sep 10, 2007.
  1. clavaud
    Jun 27, 2007
    25
    In free version v3.1.2434 the groups of calls are not possible. can you confirm it to me?
  2. 5qg4
    5qg4 Active Member
    Jan 31, 2007
    643
    Do you mean the ring groups for PSTN numbers? If I'm not wrong, build 2434 still unable to create a ring group for PSTN numbers.
    I also wait for 3CX to deploy this feature.
  3. SY
    SY Well-Known Member
    3CX Support
    Jan 26, 2007
    1,825
    I don't believe you! :shock:
    What is not possible and/or what we should confirm :?:
    Regards
  4. clavaud
    Jun 27, 2007
    25
    It is possible to create groups of call
    on the free version v3.1.2434?
    Personally I do not arrive there.
  5. tab
    tab
    Aug 10, 2007
    85
    Extension group for incoming calls: yes, something else: no.
    tab
  6. Costas3CX
    Costas3CX New Member
    Jan 23, 2007
    217
    clavaud you are confusing us. what is groups of call ? what is a group of call supposed to do? Do you mean ring groups? are you saying that in free version you cannot create a ring group? Did you create an extension first? You must have at least 1 extension before you can create a ring group.
  7. clavaud
    Jun 27, 2007
    25
    I have already create groups of ringing with the version v3.0.1928 and that functions but with the version v3.1.2434 I do not arrive there.
    I have to test on Windows 2000 pro or xp pro
    same problem. Made the test you will see that that is not possible any more
  8. 3CXsupport
    3CXsupport New Member
    Aug 21, 2006
    193
    Hi clavaud,
    The mentioned feature has passed testing and I've just given it another look and I seem to be able to create ring groups in v3.1.2434 (FREE). Maybe you are experiencing a unique issue but can you please specify exactly what is going on ?
    Are you using a foreign language?
    Are you reaching the ring groups page at all ?
    Is there something particualr missing in the ring groups page ?
    or perhaps are you able to create the ring group but it doesn't work ?
    Please bear with us and spell out the issue as clearly as possible so we can confirm that all is well.
  9. clavaud
    Jun 27, 2007
    25
    I have find the problem (i'm french).
    If you select the english langage for the GUI the creating ring group is ok (extension appear).
    But if you select french (maybe another langage) when you want to make ring group, the group will be created but extension not appear.
  10. 3CXsupport
    Aug 21, 2006
    193
    Hi clavaud,
    I can confirm that this issue is reproducable. It's quite and odd situation but it is being looked into and should be repaired by the next build.
    In the mean time can you please create any desired ring groups with the interface set to a different language ?
    Thanks for pointing this out to us!
  11. clavaud
    Jun 27, 2007
    25
    For the moment I work with the GUI English
