Ring Group
Discussion in '3CX Phone System - General' started by AEnrico, Mar 6, 2018.
  1. AEnrico
    Jan 5, 2018
    12
    Hi, sorry for my English.
    I have a ring group with 4 extensions.
    The call starts on all the phones. but one of these 4 phones was already on call.
    After 5 seconds this extension ends the previous call and would like the phones to ring as for the other 3.
    it's possible?
    10,737
    280
    Calls to a ring group do not "re-poll" ring group members, while a call is ringing, to see if one, that was busy, is now idle. You could send unanswered calls, (after a time-out), from the first group, to a second group, made up of the same members.
    You could also add a second extension to each set, that was also a ring group member. It would also ring, allowing a set to hang up the current call and take the second key.
    AEnrico likes this.
  3. AEnrico
    Jan 5, 2018
    12
  4. YiannisH_3CX
    YiannisH_3CX Support Team
    May 10, 2016
    6,016
    420
    In addition to what leejor mentioned you could also use a Queue that will re-poll agents after they hang up.
  5. AEnrico
    Jan 5, 2018
    12
    so is it possible to do what I asked?
    if yes, how?
  6. Saqqara
    Saqqara Well-Known Member
    Mar 12, 2014
    1,098
    165
