Ring groups for Fax (System) extensions
Discussion in 'Ideas' started by J616, Dec 18, 2015.
Ring groups for Fax (System) extensions 5 5 3votes
5/5, 3 votes
  1. J616
    Dec 18, 2015
    Would be nice to be able to be able to setup a hunt group for system extensions. ie: if Fax machine A is busy then it rolls to Fax B of A & B busy then roll to C and or possibly then the built in email one.
  2. Lev
    Lev New Member
    Sep 19, 2015
    127
    20
    Any improvement to faxing is welcome to me.
    Also, it makes sense if you get a lot of requests and orders via fax.
