Ring Multiple phone:
Discussion in '3CX Phone System - General' started by UmerRazi, Nov 17, 2007.
  1. UmerRazi
    Sep 21, 2007
    6
    I have three phones with ext 100, 101, 102. Phone are SPA962. I want to that when calls ext 100, then all three phones should ring with indication of extension 100, so that I can any one from any phone can attend the call. Please let me how can I do that. I tried to register ext 100 on other two phones but as soon as I register ext 100 on multiple phone, other ext 101 or 102 does not work. Does 3cx supports multiple registration of single extensions? Thanks
  2. silentfun
    silentfun Member
    Dec 11, 2006
    364
    not atm but in v4 it will come i read somewhere here in forum
    andy
  3. Mori
    Mori New Member
    Mar 23, 2007
    223
    Try setting up an Ring Group, and select the Ring Group Strategy to "Ring all"...
