Ring my mobile simultaneously grayed out
Discussion in '3CX Phone System - General' started by jmatson, Jun 4, 2011.
  1. jmatson
    jmatson New Member
    Nov 30, 2009
    122
    i was using this option in the prev version. but now that i have updated to V10. it's grayed out. my ext still rings my cell. but i can't enable it on any other ext.
  2. davidbenwell
    davidbenwell Active Member
    Apr 27, 2010
    704
    are you using the Free edition? if so this is only available in the paid versions of 3CX.
  3. wzaatar
    Aug 1, 2007
    90
    Hi there,
    I flagged this out some time ago: (http://www.3cx.com/forums/v10-disabled-features-19929.html).
    It's sad but it seems that with every new version coming out, the free one gets more crippled and features get moved to the "paid" version.
    You're better off downgrading if you want this feature back.
    Cheers,
    W.
  4. mylove4life
    mylove4life New Member
    Jan 7, 2010
    165
    Your better off buying it....
  5. mylove4life
    Jan 7, 2010
    165
  6. davidbenwell
    Apr 27, 2010
    704
    If you need a licence, we can do theses at very good rates. Visit http://www.3cx-phone-system.co.uk/3cx-phone-system.html for more info
  7. willow
    willow Member
    Mar 1, 2011
    471
    3cx has been very good a letting the average user try the pbx. Just like any company they want and need to make money. I can't blame them for limiting the features. Would cisco or avaya or intertel give you a free pbx to use? I would suggest contacting a partner in your area, they can usually work you up very good numbers on a license.
  8. KerryG
    KerryG Active Member
    Jun 19, 2009
    960
    The Free version is not designed to be a production system, it is really for doing technical testing.
