Ring on mobile
Discussion in '3CX Phone System - General' started by rockme87, Aug 14, 2014.
  1. rockme87
    Aug 14, 2014
    Hi there,
    I have the 3cx configured for 1 of my extensions to ring on my cell at the same time.
    Everything seems to be working but between 30-45 seconds the call is disconnected.
    Regular calls to extensions and outside lines perform correctly.
    Any ideas would be appreciated,
    Thank you.
    10,570
    247
    A posted copy of the 3CX log would probably help.
    Are you saying that you answer the calls (on the mobile) and it drops, or it drops while ringing? Is there voicemail enabled on the 3CX extension?
    What type of trunking are you using to send the call to the mobile?
    Is this a change in behaviour, or has it been happening from "day one"?
  3. rockme87
    Aug 14, 2014
    this is a new setup
    the disconnect happens once answered by the mobile phone. voiceMail is setup after 20 sec
    this extension is set to ring at the same time (checkbox on the bottom of extension settings)
    i will check the log now
  4. rockme87
    Aug 14, 2014
    thank you for your help I figured it out there are different settings from my provider
    based on the modem that I have it uses a different port
