Ringback for Parking Orbit
Discussion in 'Ideas' started by contoured, Apr 9, 2018.
  1. contoured
    Sep 7, 2016
    54
    5
    I would like to have the ability to configure ring back (automatic un-park) for calls placed in a parking orbit. When just looking at the Call Park Settings page it is quite easy to make the mistake of thinking that the options there would also apply to parking orbits.
    I understand that parking orbits are considered legacy and that shared parking should be used when possible, but there are some implementations where parking orbits are a much better fit.
    #1 contoured, Apr 9, 2018
