- Joined
- Aug 25, 2009
- Messages
- 1
- Reaction score
- 0
Hi There,
I'm having an odd situation here, when an external call comes in to our 3cx system the phones ring once then go straight to voicemail, and I can't see from the settings why this would be happening. Internal calls are fine also.
Below is a sample of the logs,
14:43:54.064 [CM503008]: Call(5): Call is terminated
14:43:53.908 [CM505001]: Ext.400: Device info: Device Identified: [Man: Counterpath;Mod: eyeBeam;Rev: General] Capabilities:[reinvite, no-replaces, unable-no-sdp, recvonly] UserAgent: [eyeBeam release 1102u stamp 52345] Transport: [sip:192.168.100.5:5060]
14:43:53.908 [CM503002]: Call(5): Alerting sip:[email protected]:26448;rinstance=fa96b944f7c1e49c
14:43:53.411 [CM503024]: Call(5): Calling RingAll800:200300Ext.300400Ext.400500700Ext.700100Ext.100@[Dev:sip:[email protected]:26448;rinstance=fa96b944f7c1e49c]
14:43:53.302 [CM503004]: Call(5): Route 1: RingAll800:200300Ext.300400Ext.400500700Ext.700100Ext.100@[Dev:sip:[email protected]:26448;rinstance=fa96b944f7c1e49c]
14:43:53.287 [CM503010]: Making route(s) to <sip:[email protected]:5060>
14:43:53.287 [CM505003]: Provider:[SipGate Rimcon] Device info: Device Not Identified: User Agent not matched; Capabilities:[reinvite, replaces, able-no-sdp, recvonly] UserAgent: [] Transport: [sip:192.168.100.5:5060]
14:43:53.271 [CM503001]: Call(5): Incoming call from 01970623996@(Ln.10001@SipGate Rimcon) to <sip:[email protected]:5060>
14:43:53.054 [CM503012]: Inbound office hours rule (unnamed) for 10001 forwards to DN:800
We've even tried to restore some old backups of the settings but the problem is still present, is there somewhere obvious in the settings I should be looking? The other odd thing on the ports/trunk status is says dailing on both lines, however when I click Disconnect call, I get this error, An exception occurred ExtStatus Error:
Thanks for any help,
James.
James.
