Ringroup option not answerd.
Discussion in 'Windows' started by Joop_Nolet, Feb 23, 2015.
  1. Joop_Nolet
    Feb 23, 2015
    When in a Ringroup one ore more persons are busy or not able to answer the next incoming call, I choosed the option connect to the digital receptionist, which we setted up properly en tested to work as needed.
    However, the person from outside who calls hears about 5 ringtones and than te connection is ended.
    The digital receptionist never came online.
    Is there something I forgot to setup ?
    We are currently working with version 11.....
  2. pj3cx
    pj3cx Active Member
    Aug 1, 2013
    646
    Hi there,
    Can you check if all your 3cx services are running ?
    Can you access the management console from browser ?
  3. Joop_Nolet
    Feb 23, 2015
    I have a VM server windows open with thee management console open.
  4. Joop_Nolet
    Feb 23, 2015
    OK I found out now what you mean, I have not much experience in this system as it was brought up 3 years ago and we never used things lik digital receptionist etc.
    I found all services started.
  5. leejor
    11,117
    329
    Follow a call in the 3CX server logs. It should indicate if there was an issue connecting to a destination, at the point of the ring group time-out period. If you are unsure about what the log is telling you, then post it here.
