Ringtone change and PUSH delay
Discussion in 'iOS' started by Michal Knezourek, Oct 12, 2017.
  1. Michal Knezourek
    Sep 29, 2017
    9
    We are deploying iOS clients to large amount of devices...
    Users are asking, if they can change ringtone... is it possible?
    Another think is, that if there is incoming call to phone, it will take x seconds before opening app..
    If I have queue, where it has to ring 15 seconds, and it takes more than 5 seconds to open app..it's bad... it is really random, how long it takes... the same behaviour if the phone is on wifi or lte... any ideas?
    Thank you.
    Michal
  2. Sopock
    Sopock Member
    Jul 11, 2012
    447
    20
    Maybe such large amount of devices will draw @Nick Galea attention.
    In any case, CallKit should even allow users to distinguish calls from 3CX client by setting to vibration only.
    Client can be improved by CXProviderConfiguration in which ringtone from app bundle can be specified.
  3. Vali_3CX
    Vali_3CX Well-Known Member
    Dec 12, 2008
    1,527
    71
    #3 Vali_3CX, Oct 15, 2017
  4. Michal Knezourek
    Sep 29, 2017
    9
    Hi Vali and all other people,
    I think, that push is one thing, but time for connecting call after answering is second thing...
    When I have app on phone opened and I click to answer incoming call, it will take 2 seconds to hear the other side.... in this time, the other side still hear ringing..
    People are automatically clicking answer and then they start speaking.. but because of delay it's something like click answer, "hello", "hello", "hello" :)
    Is there any best practice for setting up for best speed? Use 3CX tunnel or not, Use UDP/TCP, etc... ?
