Roaming user unable to make calls from internet
Discussion in 'Windows' started by rralamo, Jul 25, 2009.
  1. rralamo
    Aug 10, 2007
    16
    Hello All,
    I have an issue maybe someone can help me with. When I am on the internet traveling I am unable to make calls from 3CX VoIP phone (v.3.1.6288.0) outside my firewall. When I VPN in I have no issues making calls internally or externally.
    I can dial from an internal extension (x503) to the external VOIP Phone (x515) and receive two way audio/voice no issues
    I have read many of the posts here and have tried the fixes but no luck. Any help would be appreciated.
    Configuration:
    Windows 2008 Enterprise Edition with SP2 applied
    Uses IIS 7
    3CX v.7.1.7139.0 fully updated
    on all workstations
    Firewall
    NAT, ports redirected to 3CX server
    External Workstation
    Windows 7 RC
    Extension: 515
    3CX VOIP Phone v.3.1.6288.0
    Connection Settings: External
    I am out of the office – extern IP: 67.x.x.x
    No Tunnel chosen
    It will connect and show as an available extension in the 3CX management console.
    67.x.x.x is the external IP address
    Here is an excerpt of the log when I try and make a call to an internal extension:
    23:37:22.092 [CM503008]: Call(4): Call is terminated
    23:37:22.092 [CM502001]: Source info: From: "3CX VoIP Phone"<sip:515@67.x.x.x:5060>;tag=a46c826a<sip:503@67.x.x.x:5060>
    23:37:22.092 [CM503013]: Call(4): Incoming call rejected, caller is unknown; msg=SipReq: INVITE 503@67.x.x.x:5060 tid=1446cf12b31d687d cseq=INVITE contact=515@67.x.x.x:60075 / 2 from(wire)
    23:37:21.782 [CM500002]: Unidentified incoming call. Review INVITE and adjust source identification: INVITE sip:503@67.x.x.x:5060 SIP/2.0 Via: SIP/2.0/UDP 192.168.18.100:62389;branch=z9hG4bK-d8754z-a9700b322523ca3b-1---d8754z-;rport=60075;received=67.x.x.x Max-Forwards: 70 Contact: <sip:515@67.x.x.x:60075> To: <sip:503@67.x.x.x:5060> From: "3CX VoIP Phone"<sip:515@67.x.x.x:5060>;tag=a46c826a Call-ID: YzNjOTYwMWEzZGYyNWNmZjM3NDk2ZWRlY2IxNWZmMzA. CSeq: 1 INVITE Allow: INVITE, ACK, CANCEL, OPTIONS, BYE, REGISTER, SUBSCRIBE, NOTIFY, REFER, INFO Supported: replaces User-Agent: 3CXVoipPhone 3.1.6288.0
    Content-Length: 0 23:37:21.782 [CM302001]: Authorization system can not identify source of: SipReq: INVITE 503@67.x.x.x:5060 tid=a9700b322523ca3b cseq=INVITE contact=515@67.x.x.x:60075 / 1 from(wire)
    Thank you
    Rene Alamo
  2. discovery1
    discovery1 Member
    Aug 4, 2008
    355
    Start here
    http://wiki.3cx.com/documentation/voip-providers/how-to-solve-source-identification-issues
  3. leejor
    11,117
    329
    I'm curious as to why both extensions, internal and external have IPs that both begin with 67 and this wasn't a tunnel or VPN call.
  4. rralamo
    Aug 10, 2007
    16
    Hi Discovery1
    Thank you for your reply. I have a question; I looked at the link, since these are extensions which are registered to the 3CX server I am not using a "Provider" to dial to each other so why would I need to change anything?
    Hi Leejor,
    Thank you for your question. They both have 67.x.x.x since I have a block of IP's from my service provider
    x503 (internal not roaming) would be connected to the 3cx server and the 3CX server connected to the internet through my ISP's router would be 67.x.x.25
    x515 would be connected to the internet through my ISP's router would be 67.x.x.26
    I use this for testing since both systems are on differnet networks
    Regardless of where I connect (airport, coffee house or hotel) I receive the same error
    Any help from anyone would be gratedully appreciated.
    Thank You
    -RRAlamo
  5. Vali_3CX
    Vali_3CX Well-Known Member
    Dec 12, 2008
    1,528
    71
    We just released two days ago a new version of our 3CX Voip Phone, labelled 3.1.8571. It has no many features added, but several important issues fixed. Please try it, if it doesn't work too, then I will ask for some furhter informations.
    Regards
    vali
  6. rralamo
    Aug 10, 2007
    16
    Hi Vali,
    I installed the latest version as you recommended and i stil have the smae issue.
    Thank You,
    RRALAMO
  7. DeWild1
    Oct 31, 2008
    86
    Try thei 4.o beta, located on the top of this forum.
  8. leejor
    11,117
    329
    What do your 3CX logs show when the softphone first registers? Is Stun enabled at the remote end, and all of the ports open on your firewall/router?
