Root DN and AD/LDAP integration
Discussion in '3CX Phone System - General' started by jeinstei, Apr 7, 2012.
  1. jeinstei
    Mar 31, 2012
    10
    Hey-
    I don't even care if someone doesn't know the answer, but my last 2 posts were completely unanswered. Anyone had any experience using non-root DN, such as "ou=one,ou=two,ou=root"? Currently, can you only type in the domain name?
    Best
  2. craigreilly
    craigreilly Well-Known Member
    Feb 1, 2012
    3,129
    207
    Is this for extension import?
    I did a partial - just to update existing extensions with cell
    Phone I think. But encountered no issues. All of my users are in folders not within the default users folder.
  3. jeinstei
    Mar 31, 2012
    10
    This is a partial, and the root DN doesn't have the users. Being an SBS server, the users are in MyBusiness > MySomething > Users. Unlike a standard AD install, the users are farther down so it doesn't find anything using the domain as a root DN.
    So it just found the users immediately no problem? I wish the feature was documented a bit better. I'm glad to hear that it worked for someone else; my ldap browsers find the users no problem.
  4. craigreilly
    Feb 1, 2012
    3,129
    207
    We are on server 2003.
    I already had extensions with users via CSS import.
