route based on work hours (NOT myphone!!!)
Discussion in '3CX Phone System - General' started by twistedtech, Oct 5, 2011.
  1. twistedtech
    Sep 22, 2011
    how can I route after hours call to a different call menu? the only thing I see is for myphone and that wont work
  2. chris.mccune
    Oct 8, 2011
    I assume you mean for incoming calls.
    If you look in the management console under inbound rules, there is a check box that allows you to set up different route depending on office hours.
    Is that what you are looking for?
    Chris
