Route calls per weekday on 1 trunk
Discussion in '3CX Phone System - General' started by revilo951, Feb 21, 2018.
  1. revilo951
    Nov 12, 2016
    25
    Is it possible to set incoming calls on a trunk to be routed to a different extension per day of the week? EG on Sat-Wed, route to extension 201, on Thur-Fri, route to extension 202.
  2. daktur
    daktur New Member
    Oct 15, 2015
    230
    8
    @revilo951 ,
    You may set the working hours and out of office hours to have different behaviours on different days / hours of the day.
    This way during working hours one extension / ring group / queue will ring and during out of the office hours the other one will ring.
    Hope you succeed, best luck!
  3. voiptoys
    voiptoys Active Member
    Feb 13, 2013
    891
    156
    Assuming your office hours are different than the need to route the calls to different extensions, you could write a CFD application that looks that the day of the week and transfers calls appropriately. On your inbound rule, transfer the call to the CFD, then the CFD will transfer to the appropriate extension. It will be fast enough that your caller will never know.
  4. revilo951
    Nov 12, 2016
    25
    @daktur Thanks, that will work, except I cannot choose a different VM box for after hours. It's what I'm doing ATM.
    @voiptoys I looked at using CFD, but I know no C# - would it be difficult to do?
  5. voiptoys
    Feb 13, 2013
    891
    156
    Would it be difficult to build a routing CFD? I don't think so. Conceptually, it's VERY simple. In the designer add a "Date & Time condition" and add as many conditions as you need. Next, add a transfer component to each condition (pointing to the correct extension). I think that's all there is to it. I don't think you even need any C# code. You should be able to do everything right in the designer.
    Now, if you want to add some flexibility, for example, lookup the desired transfer extensions rather than hard-code the values, that's easy enough too. You could store these values in a database or text file. That gets a tiny more complicated, but this should be about as simple as it gets.
  6. revilo951
    Nov 12, 2016
    25
    OK, where's a good place to start learning about CFD?
  7. Saqqara
    Saqqara Well-Known Member
    Mar 12, 2014
    1,336
    222
  8. revilo951
    Nov 12, 2016
    25
    Thanks, that looks good. We have a Pro licence.
