Route Outbound PSTN to Specific FXO Port
Discussion in '3CX Phone System - General' started by lav180, Jan 20, 2009.
  1. lav180
    Mar 17, 2008
    Hi All,
    3CX = 6.0.806.0
    Gateway
    Patton 4114 H/W V4.4 S/W R4.2
    It's all up and running OK, Green check marks on all FXO Ports and Extensions.
    I would like to be able route Outbound PSTN calls through specific FXO ports, one for my business the other for home.
    I set up the Patton using the Config supplied by 3CX.
    On the Outbound rule screen I can't see a way of stating that the rule should use the virtual extension number associated with the FXO port which would thus force that call out on a particular PSTN line.
    Look forward to any advice offered.
    TIA,
    Pete
  2. discovery1
    discovery1 Member
    Aug 4, 2008
    355
    The details from this topic may help
    http://www.3cx.com/forums/routing-extensions-to-specific-outbound-ports-8574.html
  3. lav180
    Mar 17, 2008
    Hi All,
    Thanks for the pointer. I read that before posting but for some reason it didn't make sense. I found this answer http://www.3cx.com/forums/port-selection-for-outbound-calls-on-patton-4114-incorrect-8587.html from William400 which made perfect sense, they may have been saying the same thing. Anyway carried out change, set up rules, made calls and it's all working OK. Now just need to set up different ring tones for each line and I'll be happy.
    Thanks William400
    Cheers,
    Pete
