Route to IVR on Holiday
Discussion in '3CX Phone System - General' started by DesCheah, Dec 22, 2014.
  1. DesCheah
    Dec 22, 2014
    10
    I'm setting up holiday mode for Christmas using customized Christmas prompt. How to configure incoming call route to IVR when holiday mode is set?
  2. craigreilly
    craigreilly Well-Known Member
    Feb 1, 2012
    3,554
    300
    Have you been to Settings- General to "Configure Holidays"
    Then under the "EDIT PORT"-> Other Options of the trunk -> "Play Holiday Prompt on Public Holiday"
  3. DesCheah
    Dec 22, 2014
    10
    Thanks Craig, that's handy...Cheers, mate.
