Router Recommendation
Discussion in '3CX Phone System - General' started by uk26, Jan 26, 2011.
  1. uk26
    Mar 25, 2009
    12
    Anyone used this router before with 3CX
    Draytek Vigor 2820Vn
    http://www.amazon.co.uk/Draytek-Vigor-2820Vn-Wireless-Ethernet/dp/B001EN7GZO
    Need to be able to have full firewall support to blcok udp / tcp ports on 5060 and only allow Voip Provider access
    Does this rotuer do this??
    also it says Twin VoIP ports with PSTN passthrough ('V' models only)
    does this mean it can be connected to 3CX as a gateway?
