Routing Calls from Mitel thru 3CX to Voip Provider
Discussion in '3CX Phone System - General' started by ormondcollege, Oct 29, 2014.
  1. ormondcollege
    Oct 29, 2014
    I have setup our 3CX server to talk directly to our Mitel ICP 3300 as a VoIP Gateway, and have got calls going to and from 3CX<->Mitel working successfully.
    What I can't seem to enable, is to allow calls from the Mitel, thru the 3CX server to go out via a VoIP Provider. For example
    Mitel (x1267) -> 3CX (x3000) - Works
    3CX (x3000) -> VoipProviderA (0487XXXXXX) - Works
    Mitel (x1267) -3CX with destination of 0487XXXXXX - does not work, I am getting the following in the log files....Does anyone know how I enable the 3CX server to accept and process calls from one VoIP Gateway/Provider and out another ?
    I have the 3CX-Mitel link setup as no authentication required.
    30-Oct-2014 10:33:30.147 [CM102001]: Authentication failed for AuthFail Recv Req INVITE from 10.0.30.2:1732 tid=821821072-103122205 Call-ID=821601072-103122201:
    INVITE sip:00487318399@10.0.30.7:5060;transport=tcp SIP/2.0
    Via: SIP/2.0/TCP 10.0.30.2:5060;branch=z9hG4bK821821072-103122205
    Max-Forwards: 26
    Contact: "Tony Burn"<sip:1267@10.0.30.2:5060;transport=tcp>
    To: <sip:00487318399@10.0.30.7>
    From: "Tony Burn"<sip:1267@10.0.30.2>;tag=0_821601072-103122203
    Call-ID: 821601072-103122201
    CSeq: 3 INVITE
    Session-Expires: 90;Refresher=uas
    Min-SE: 90
    Allow: INVITE, BYE, CANCEL, ACK, INFO, PRACK, OPTIONS, SUBSCRIBE, NOTIFY, REFER, REGISTER, UPDATE
    Proxy-Authorization: Digest username="9901",realm="3CXPhoneSystem",nonce="414d535c0a620a4957:b10583229a5a426d1cdfaccb1b21b5ce",uri="sip:00487318399@10.0.30.7:5060",response="f597aa888a51e5e13dfd661f4824c6ec",algorithm=MD5
    Supported: timer
    User-Agent: Mitel-3300-ICP 13.0.0.80
    Content-Length: 0
    ; Reason: Credentials don't match, check that authorization-ID and password match the ones in extension settings
    30-Oct-2014 10:33:30.147 [CM500002]: Unidentified incoming call. Review INVITE and adjust source identification:
    Invite-UNK Recv Req INVITE from 10.0.30.2:1732 tid=821821072-103122205 Call-ID=821601072-103122201:
    Max-Forwards: 26
    CSeq: 3 INVITE
    Min-SE: 90
    Supported: timer
    Content-Length: 0
    30-Oct-2014 10:33:30.146 [CM302002]: Authentication failed due to unidentified source of: SipReq: INVITE 00487318399@10.0.30.7:5060 tid=821821072-103122205 cseq=INVITE contact=1267@10.0.30.2:5060 / 3 from(wire)
    30-Oct-2014 10:33:29.870 [CM500002]: Unidentified incoming call. Review INVITE and adjust source identification:
    Invite-UNK Recv Req INVITE from 10.0.30.2:1732 tid=821601072-103122202 Call-ID=821601072-103122201:
    Via: SIP/2.0/TCP 10.0.30.2:5060;branch=z9hG4bK821601072-103122202
    Max-Forwards: 26
    CSeq: 1 INVITE
    Min-SE: 90
    Supported: timer
    Content-Length: 0
  2. jasit
    jasit New Member
    Feb 12, 2013
    172
    On the Mitel did you setup a trunk to the 3cx or a extension?
    The best way I have seen to setup the two boxes is by creating a trunk on the mitel and a master bridge on 3cx. If that doesn't work, then a trunk on the Mitel to a extension on a the 3cx.
    The trunk on the mitel will need to have the routing setup and 3cx will need to have the same outbound route setup. The one thing that you will lose is the caller id information from the mitel, everything will go out as the extension number on 3cx
    jasit.
  3. ormondcollege
    Oct 29, 2014
    I also tried that, by creating an extension on 3CX and then on the Mitel setting up the Sip Peer using that extension and authentication, and could see that it registered on the 3CX server.
    Internal calls works to 3CX extensions, but it would not send the calls out thru a VoIP provider, even though the call was showing in the logs as coming from the registered extension.
    Maybe i'll just have to wait for local 3CX engineer support to sort it out.
