Routing SIP signaling message to a WAN emulator
Discussion in '3CX Phone System - General' started by abhishek, Mar 28, 2011.
  1. abhishek
    Mar 28, 2011
    Hello Everybody,
    I have implemented a set up where 3CX SIP client has to send SIP signaling messages to a WAN emulator. The WAN emulator (creates packet loss, delay etc) then forwards the signal to the SIP server. For this I added a route "route add 192.168.10.1 mask 255.255.255.255 192.168.20.4" in command prompt of windows machine where my SIP client is installed. Here 192.168.10.1 is my SIP server and 102.168.20.4 is my WAN emulator.
    I noticed that the SIP invite does not initiate when I add the above route. The SIP invite initiates after I remove the static route from windows machine. Ex: When I dial a remote extension "200" , the 3CX phone gives me an error "Destination not found" .
    I took a wire-shark trace and observed that I am receiving "SIP 404 not found error".Correct me if I am wrong but I guess there is problem with the SIP server(asterix).
    Can some one help on this. TO route SIP signaling messages through a emulator and then to the SIP server.
    Note: SIP clinet , router interface 1, and WAN emulator are connected to a switch. Router interface 2 is connected to SIP server.
    Any help on this is highly appreciated!!! Many Thanks
    Abhishek
