RTP Packets
Discussion in '3CX Phone System - General' started by Hjalmar, Sep 4, 2007.
  1. Hjalmar
    Aug 6, 2007
    5
    16:31:49.505 MediaServerReporting::RTPReceiver [MS105000] Call(1) Ln:10000@Budgetphone: No RTP packets were received on 00000001@:remoteAddr=85.17.186.6:61238,extAddr=84.104.196.236:9000,localAddr=0.0.0.0:9000
    Do anyone know this problem, and how to sovle it ?
  2. nb
    nb Support Team
    Jun 7, 2007
    2,153
    175
    Firewall issue - NAT issue. Check your firewall. You have one way audio.
  3. Hjalmar
    Aug 6, 2007
    5
    Do you have a port that i can allow?
  4. 5qg4
    5qg4 Active Member
    Jan 31, 2007
    643
    Please take a look at this post. List of default ports used by the 3cx phonesystem
    http://www.3cx.com/forums/viewtopic.php?t=1697
  5. SY
    SY Well-Known Member
    3CX Support
    Jan 26, 2007
    1,825
    Please pay attention that firewall problems can "live" not only on PBX host, and happen not only with 3CX :)
    Check route from remoteAddr=85.17.186.6 to extAddr=84.104.196.236 regarding to firewalls... If these addresses are gateway addresses, then check route from local entity (PBX, or phone on other side) to its gateway. as well as check NAT device.
    Also, please use search on forum before describing your problem in new thread, because your problem could be discussed already.
    For example:
    http://www.3cx.com/forums/viewtopic.php?t=2201&start=0&postdays=0&postorder=asc&highlight=
    There is a ryan's story about fighting with network. I hope you will find some hints there...
    Specified message means exact what it says. No RTP stream were received by PBX from remote party 85.17.186.6:61238
    Regards
  6. Hjalmar
    Aug 6, 2007
    5
    Problem has been solved. It's a firewall in Windows 2000.
  7. nb
    nb Support Team
    Jun 7, 2007
    2,153
    175
    Good - happy your problem is resolved. Enjoy 3CX Phonesystem
  8. stef69
    Jul 1, 2007
    7
    Same problem but no firewall
    same problem but no firewall i post my config
    remote SIP:
    software sip X-lite with public STUN
    laptop on the DMZ
    no firewall on laptop
    extention configured as external and bind to media server
    3CX server:
    no firewall
    server beind router all port forward to the local port host.
    extention registered: OK
    ringing internal : OK
    ringing external: OK
    But
    no sound external and internal
    piece of log calling extention 101 from 100
    [MS105000] Call(2) Ext.100: No RTP packets were received on 00000004@:remoteAddr=82.229.204.XXX:11216,extAddr=81.80.23.XXX:35121,localAddr=0.0.0.0:9006
  9. SY
    3CX Support
    Jan 26, 2007
    1,825
    Re: Same problem but no firewall
    Check routing and packet delivery between specified hosts. (from 82.229.204.XXX to 81.80.23.XXX)
    BTW, your PBXHost:9006 translated to 81.80.23.XXX:35121. Is it expected?
    Regards
  10. stef69
    Jul 1, 2007
    7
    thanx for your quick answer
    localAddr=0.0.0.0:9006 isnt a problem ?
    how can i do ? a tracert command in a prompt ?
    its when packet went from Private IP HOST ----> Router ---> external IP Adress ?
    its configured in the router ?
  11. SY
    3CX Support
    Jan 26, 2007
    1,825
    No, it is not. extAddr=0.0.0.0 for local destinations and localAddr=0.0.0.0 for external. If both will be(or not be) a 0.0.0.0 then it will be a problem in software :)
    I think tracert will not help you, because it just checks general accessibility of host. There are lot of things that can have an influence in specific case.
    Yes, "Router" in your scheme is responsible entity. In general, Router has Firewall and NAT built-in.
    Please pay attention that your scheme is symmetric, I mean not only 3CX host configuration influences delivery of audio and/or signaling
    Full scheme is:
    Private IP HOST <----> Router <---> external IP Adress <--->INTERNET<----->external IP Address2<------->Router2<------->Private IP HOST2
    Regards
