rtp port and audio problem
Discussion in '3CX Phone System - General' started by yanirda, May 31, 2012.
  1. yanirda
    Sep 24, 2010
    28
    my sip provider is use rtp port:
    10000-20000
    how i change\ configure it in the 3cx system???
  2. craigreilly
    craigreilly Well-Known Member
    Feb 1, 2012
    3,530
    298
    Settings then Network. Bottom item is VOIP Ports. Is this what you are looking for?
  3. yanirda
    Sep 24, 2010
    28
    the network port(wan)
    is change to 10000-20000
    i have incoming and out going calls,
    registration is fine,
    but i dont have sound!
    what else can i do?
    the voip provider say that there is no rtp packets..
    what i do wrong?
    thanx in advance!
  4. lneblett
    lneblett Well-Known Member
    Sep 7, 2010
    2,086
    64
    Did you restart the 3cx services to ensure the system is now using the desired ports?
    Did you port forward the ports (10000-20000) in your firewall to your 3cx system...as well as port 5060?
  5. yanirda
    Sep 24, 2010
    28
    yes i did it all
    forward in fw
    restart system..
    what else can i do or check?
    thnx
  6. lneblett
    Sep 7, 2010
    2,086
    64
    What country are you located and who is provider?
  7. craigreilly
    Feb 1, 2012
    3,530
    298
    I have also seen errors with outbound packets being blocked. Might want to check that all traffic from outbound from the Phone Server is not blocked.
  8. SY
    SY Well-Known Member
    3CX Support
    Jan 26, 2007
    1,825
    Completely not clear...
    Your Voip provider is free to use any ports. The same on 3CX Phone System side - you can configure any set of ports on your NAT.
    Could you please specify model and settings of of your router (ISP)
  9. yanirda
    Sep 24, 2010
    28
    thnk you all,
    the problem solved,
    there was block in the fw (sbox)
    in the function "smart defense" disable the sip function there,
    and it work like magic,
    thank you all!
