RTP proxy
Discussion in '3CX Phone System - General' started by cuneytsaltik, Mar 28, 2007.
  1. cuneytsaltik
    Mar 28, 2007
    First, i want to thank about building such a useful program. I
  2. archie
    archie Well-Known Member
    3CX Support
    Aug 18, 2006
    1,299
    Currently, this ability is not supported. Either 1) you specify VoIP as not bound to MS, and in this case your internal extensions should be able to provide externally visible IP to it as well as external extensions do, or 2) you bind VoIP to MS, and than all extensions will pass RTP to it thru MS.
