Rules inbound/outbound between extensions groups
Discussion in 'Ideas' started by itgs, Jan 12, 2018.
  1. itgs
    Nov 8, 2008
    58
    Add the ability to apply DID rules to Extensions Groups and not only to extensions (like now).
    This could be useful, for example, if a company have many offices branches and want to isolate some users communications .
    Thank you
  2. Tobias Pieper
    Dec 31, 2017
    6
    This Feature is already exist... or I understand the question wrong .. ? Hmm...
    This is Outbound:
  3. itgs
    Nov 8, 2008
    58
    I already tried, but it does not work.
    Example:
    Calls to numbers starting with prefix: 1 (to block all calls for extensions starting with 1xxx)
    Calls from extensions Group: GroupName
    Calls block on all routes
    This method is not good because there could be telephon numbers starting with same numbers of the extensions (for example in Italy "3" digit is for mobile phone).
    I think could be useful to have a "low level rules" acting directing to extensions but using groups for applying it.
    Thank you
