Run 3CX Fax Service on Windows 2012 R2
Discussion in '3CX Phone System - General' started by sjhosseini, Dec 19, 2017.
  1. sjhosseini
    Dec 19, 2017
    I installed fax service features in Windows 2012 R2 and wanna to send a fax via 3CX.
    For this I need to install 3CX fax server driver but I couldn't find this driver anywhere.
    I try http://www.3cx.com/downloads/3CXfaxserver.msi but I couldn't to download it.
    Anybody can help me?
    Thanks.
  2. sip.bg
    sip.bg Active Member
    Nov 7, 2016
    704
    219
    3CX is not supporting sending fax, unless you use an ATA and fax machine.
    Fax server for sending faxes was available long time ago, may be in version 7.
    Currently only fax-to-mail, i.e. receiving faxes is supported by 3CX on T.38 capable trunks, for all other operations you need an ATA and a fax-machine.
    YiannisH_3CX likes this.
  3. sjhosseini
    Dec 19, 2017
    Thank you for your answer.
    Do you have any recommendation about T.38 solution for Windows 2012 R2 that able to connect 3CX server and send fax to mailbox?
  4. sip.bg
    Nov 7, 2016
    704
    219
    sjhosseini likes this.
  5. perfectcast
    Apr 27, 2016
    7
    Depending on your SIP trunk provider they may have a fax service which will mean you don't have any hardware to procure/administer
    We have this with our provider, basically you email a pdf of the fax service to an email address including the destination number and it gets sent.
    for incoming faxes an internal mailbox is set-up to receive fax comms also via pdf
    Neil.
  6. schmork
    Dec 20, 2017
    7
    7
    We use http://www.t38faxvoip.com/fsp/ it works as a virtual modem and you can use Windows Fax Service to receive faxes from the system. Depending on volume you can add more port licenses and receive more simultaneous calls. It will require you to install it on a separate server or else you may have some port conflicts since it acts as a SIP client.
