Solved Run Backup From Command Line
Discussion in '3CX Phone System - General' started by hwcltjn, Oct 12, 2017.
  1. hwcltjn
    Aug 16, 2017
    26
    Hi guys,
    Password for the admin login has been misplaced - I know it can be recovered by looking at the XML file in the backup. It seems as though the last backup was taken a while ago and the password has since changed. The username might have been changed as well.
    Still have root access to the server though...
    Is there a way to to trigger a backup from the command line or reset the password from the command line?
    What about running a query directly on the db?
    v15.5 - Debian
    Thanks!
  2. GiannosC_3CX
    GiannosC_3CX Guest
    Hi hwcltjn,
    I have sent you a PM please check your inbox.
  3. YiannisH_3CX
    YiannisH_3CX Support Team
    May 10, 2016
    7,448
    541
    The issue has been resolved as the password was recovered
