run Exe
Discussion in '3CX Phone System - General' started by gerlow, Apr 15, 2009.
  1. gerlow
    Apr 6, 2009
    8
    I am using the Free version of 3cx with a demo license installed. It is up and running and I have calls coming from one Voip provider and all the call from that provider is forwarded directly to an outside number. It works!
    but I want a exe to be runned when a call is coming in, I have the Assistant and I set the preference in the Assistant to run notepad.exe just to test but it only works if I send the calls to an Extension, then is starts the exe. but when I connect the calls direct to Outside number nothing happens.
    I have tried several different settings with the "Notify xeternal program on my incoming call"s and the "Notify on system incoming calls..."
    How do I set the 3cx to start for all calls to my 3cx without regarding forward to outside?
    Thanks!!
    /Staffan
  2. gerlow
    Apr 6, 2009
    8
    Thx Matt!
    Anybody knows if it necessary to have a license to start a exe in assistant when call incoming to system ?
    /Staffan
  3. William400
    William400 Well-Known Member
    Aug 21, 2006
    1,005
    HI
    Yes, such functions will require a license key.
