Run multiple SBC Instances on one host
Discussion in 'Ideas' started by 3cxsbx, Jul 13, 2016.
  1. 3cxsbx
    Nov 18, 2015
    28
    We have several scenarios where it would make sense to have multiple sbcs on one physical host (e.g. doctors that share facilities, etc.):
    * currently you need to provide one host per sbc.
    * if you have a powerful host it should be possible to have x sbcs on that host to provide services for multiple customers
    * as with mt 3cx server there could be up to x instances each running as separate service and listening on his port
