Run reports on local PC, not 3CX server?
Discussion in '3CX Phone System - General' started by shiftf7, Aug 5, 2011.
  1. shiftf7
    Mar 12, 2009
    22
    We want to be able to use this feature but not have to log onto the server every time to do so. Is there a way to run the call log reports on a local computer (on the same LAN as the 3CX server)?
    Thanks in advance.
  2. willow
    willow Member
    Mar 1, 2011
    471
    not at this time.
