Run the HTTP(S) services for remote users and the admin dashboard on different ports
Discussion in 'Ideas' started by JonnyM, Mar 3, 2017.
Run the HTTP(S) services for remote users and the admin dashboard on different ports 5 5 23votes
5/5, 23 votes
  1. JonnyM
    May 17, 2010
    77
    5
    As title really. I do not want to have the admin interface for my phone system accessible remotely at all - I have a VPN for management duties. However, I can't firewall off the port that it runs on because this breaks certain features for remote users.
    Please consider running user-facing services and the administration portal on different ports.
    BayMitch, eagle2 and AnneD like this.
  2. lopeztaz
    Mar 19, 2013
    9
    My fix for the issue. Use at your own risk!
    The management console seems to be accessed under wwwroot while all other functions are passed to the proxy. This fix works by limiting access to wwwroot and redirecting the error page to proxy which returns a denied page for the management console. You can choose what subnets to allow. Tested under v15 SP4 only.
    *******Windows Install********
    Windows Path
    \Program Files\3CX Phone System\Bin\nginx\conf\nginx.conf
    Original located under:
    server {
    listen 5001 ssl;
    Look for:
    location / {
    index index.html;
    root "C:/ProgramData/3CX/Data/Http/wwwroot";
    try_files $uri $uri/ @proxy;
    And replace with the following:
    location / {
    error_page 403 = @denied;
    allow 192.168.0.0/16;
    allow 172.16.0.0/12;
    allow 10.0.0.0/8;
    allow 127.0.0.1;
    deny all;
    index index.html;
    location @denied {
    *******3CX Appliance********
    Linux Path
    /var/lib/3cxpbx/Bin/nginx/conf/nginx.conf
    server {
    listen 5001 ssl;
    Look for:
    location / {
    index index.html;
    root "/var/lib/3cxpbx/Data/Http/wwwroot";
    location / {
    allow 10.0.0.0/8;
    allow 127.0.0.1;
    deny all;
    index index.html;
    location @denied {
    sip.bg, exevi and eagle2 like this.
  3. tratz
    tratz New Member
    Oct 21, 2015
    105
    15
    I am not sure how they would ever implement this. Depending on how you install the product, they wouldn't have a way to know what subnets to block off (aka installing on a cloud server in OVH, that is the one and only interface to them, so disabling that would eliminate all access to the web interface). I can see this for a on prem solution mostly but since it is one installation for both, I just don't see them doing this although i have been wrong before.
    --Tracy
  4. Sopock
    Sopock Member
    Jul 11, 2012
    448
    20
    How to allow only "normal" users to MC?
    Webconfigtool also should not be available from WAN!
    To run it, enter the IP followed by port 5015 (eg. http://10.172.1.88:5015) in a browser on another machine.
    https://www.3cx.com/docs/manual/configuration-tool/#h.8e3ybf57sm8n
    This may take some time. Once done, a confirmation page will be shown with important information. Make a screenshot and/or print this information - it can not be retrieved afterwards!
    Such important information only can see anybody in the middle?:oops:
  5. NTB Inc
    May 2, 2017
    21
    10
    +1
    Especially in larger enterprises, having management access available with other services is a BIG negative and in most cases would violate policies. This issue is currently delaying our ability to use more mobile/remote devices as we don't wish to expose admin access externally.
    exevi likes this.
  6. accentlogic
    accentlogic New Member
    Nov 14, 2013
    161
    66
    +10
    If any available port can be used for the console and use an alternate URL/SSL cert that would be fantastic.
  7. Accurro
    Mar 19, 2017
    Just found this after posting in this thread.
    This will be more important with the upcoming web client in 15.5, makes sense to have the web client and presence on one port, management on another.
  8. divorcer
    Apr 28, 2014
    Were you able to get this to work in v15.5?
  9. sip.bg
    sip.bg Active Member
    Nov 7, 2016
    704
    219
    Seems not working in version 15.5 (sp2).
    I was able to do the opposite -- to allow access at port 5000 from trusted public IP addresses, but not to limit public IP addresses to access webroot at port 5001.
  10. RogerS
    Dec 12, 2017
    13
    7
    It should definitely be possible to restrict the access to the 3CX Management Console for a defined IP range.
  11. Silly English Kniggit
    Sep 13, 2017
    215
    76
    Being able to run this over the WAN is by design, and very helpful for cloud installs (if you don't want to use command line). Once PBX is configured, this goes away anyway. If you don't want it available from WAN then don't open the port on the firewall?
  12. stever
    Sep 25, 2017
    39
    12
