Running 3CX Phone on Win 8 Pro x32
Discussion in 'Windows' started by ludidomagoj, Jun 5, 2013.
  1. ludidomagoj
    Aug 10, 2010
    13
    I started to reinstall PC and put Win 8 Pro instead Win 7 Pro (where it all worked).
    So it's same hardware BUT new problems came up:
    1. PC speaker ringing is dead! (even with beep.sys "hack")
    2. lots of packet drops, lags, funny sounds and buzz while talking over 3CX Phone.
    Win 8 firewall allows all for 3CXphone.exe.
    3CX Phone v6.0.26523.0 over 3CX PBX v10 with latests SP.
    Best Regards,
    Domagoj Veršec
    Logika d.o.o.
    Croatia
  2. jpillow
    jpillow Well-Known Member
    Jun 20, 2011
    1,342
    Doesnt look like v10 supports windows 8,.
  3. ludidomagoj
    Aug 10, 2010
    13
    Ok, if it's EOL I'll install v11.
    I'll write you if there are any difference at all.
