Running the 3CX Web Client as an APP
Discussion in '3CX Phone System - General' started by stefan, Jun 14, 2017.
  1. StefanW
    Jun 2, 2009
    1,236
    96
    The_Niels and jed like this.
  2. DL_
    DL_
    Mar 31, 2015
    55
    8
    An easier way...
    Open the 3CX web client in Google Chrome then click the 'three dots' menu to the far right of the taskbar.
    Choose 'More Tools' ... 'Add to Desktop' and make sure 'Open as a window' is selected.
    This will create an app shortcut on your desktop and add it to your app library and will use the 3CX icon on the desktop and other shortcuts as well (rather than the Chrome icon)
  3. craigreilly
    craigreilly Well-Known Member
    Feb 1, 2012
    3,587
    309
    MAC: https://applicationize.me/now
    1: Paste the website: https://ippbx/webclient (replace with your actual IP or Domain Name)
    2: Goto the chrome extension installer: chrome://extensions/
    3: Drag the downloaded extension from download folder into the chrome extension installer
    #3 craigreilly, Jun 14, 2017
  4. StefanW
    Jun 2, 2009
    1,236
    96
    We currently investigating an issue with the provided guide. It should read --app but while reading the document from a 3rd part source it strips one of the two dashes. Sorry for this...
