"Runtime error" message
Discussion in 'Windows' started by Vali_3CX, Nov 21, 2009.
  1. Vali_3CX
    Vali_3CX Well-Known Member
    Dec 12, 2008
    1,431
    61
    Hi, all
    I'm interested to know if somebody, excepting DeWild1, which reported this issue, encountered on 3CXPhone.exe the error message box shown below.
    If yes, I will ask you to provide some details, useful to locate and fix this issue:
    - 3CXPhone version, as shown in its About menu
    - if Plantronics were used (and Plantronics model)
    - which action - or actions sequence - seems to trigger the error message box.
    At this moment, it seems to be related with integrated Plantronics support, but we aren't able to reproduce it on our environment, that's why I'm asking you.
    Thanks for help
    vali
  2. ice
    ice New Member
    Jun 11, 2008
    108
    I have the same problem on Vista Home Basic
    - no headset
    error appears when 3CXPhone tried to connect to the server.
    how to solve?
  3. Vali_3CX
    Dec 12, 2008
    1,431
    61
    Hi, Vladimir
    Which version of the phone do you have, the latest one, 10373?
    However, please try the following: with the phone not running, rename its whole folder in your user's profile, lets say
    from
    C:\Documents and Settings\vladimir\Local Settings\Application Data\3CX VoIP Phone
    rename it as
    C:\Documents and Settings\vladimir\Local Settings\Application Data\__3CX VoIP Phone
    Then start the phone and create an account to the server to which previously crashes and tell me if this happen again now.
    vali
  4. ice
    ice New Member
    Jun 11, 2008
    108
    Thanks it works!
    3CX Phove ver 10373.
    For Vista path c:\users\_USERNAME_\appdata\3cx voip phone
  5. Vali_3CX
    Dec 12, 2008
    1,431
    61
    Hi, Vladimir
    I'm glad it's working, but I want to know what's happened :mrgreen: I'll send you a PM.
    vali
  6. Vali_3CX
    Dec 12, 2008
    1,431
    61
    OK, we located that issue and the next release will have it fixed.
    Thanks for help!
    Best regards
    vali
