Sage CRM Integration
Discussion in 'CRM / Helpdesk / App Integration' started by allendalegroup, Oct 7, 2016.
  1. allendalegroup
    Oct 7, 2016
    We're currently using the 3cx system with our Sage CRM system and while the core functionality works, i.e; being able to call out from Sage CRM.
    However, we're really in need of the ability for the 3CX system to log that the call has occurred by creating a communication record in Sage CRM.
    Is there any indication on when the integration is likely to be released? Again we're really interested in getting this integration applied to our system.
    Many thanks,
    Allendale Group
  2. edossantos
    edossantos Support Team
    Jun 27, 2007
    1,677
    131
    Can you please confirm exactly what software are you using? 3CX supports ACT! (formerly Sage ACT, now Swiftpage ACT), but Sage CRM is a different product which is not supported by 3CX. Can you check if you're using Sage ACT or Sage CRM?
    Kind regards.
  3. allendalegroup
    Oct 7, 2016
    Hi Edosantos
    We're using Sage CRM 7.2e not Sage ACT!
    I was told by your telephone support that integration with Sage CRM was in the pipeline, I was expressing a keen interest in this future integration and enquiring whether anyone may know when this is likely to be ready for use.
    Thanks,
    Allendale Group
  4. edossantos
    Jun 27, 2007
    1,677
    131
    I can't tell if it's in the pipeline or not, but for sure it is not supported right now...
    You can always develop the integration yourself, quite easily now using the Visual Studio template provided by 3CX:
    http://www.3cx.com/blog/releases/crm-integration-diy/
    Kind regards.
