Salesforce Client Pops Don't Always Find Record
Discussion in 'CRM / Helpdesk / App Integration' started by Sam Smith, Mar 13, 2018.
  1. Sam Smith
    Dec 14, 2017
    11
    Sometimes, pops don't find an existing record, even when they should.
    However, pops always find a record if that record was created from 3cx.
    Here's what I think may be happening: Instead of Salesforce storing phone numbers as digit strings (which 3CX is searching for), the numbers are stored with formatting like (555) 555-5555, if that's how the field was formatted when it was typed/imported.
    Since 3cx is creating new records in the format it likes (raw digit strings), it finds those records.
    Someone please disavow me of the notion that Salesforce is dumb enough to store formatting inside its data fields instead of stripping them down to raw digits and adding the visual representation of area code parentheses and dashes in the number on the visual side after the fact.
    Or offer another reason why this behavior is happening.
  2. edossantos
    edossantos Support Team
    Jun 27, 2007
    1,600
    125
    Hello @Sam Smith,
    Are you using the server side or client side integration? If you're using the server side, please note that Salesforce requires that you specify a contact lookup length of 7 or 4, as explained at the end of this guide:
    https://www.3cx.com/docs/salesforce-crm-integration/
    If you're using the client side integration, the plugin searches for numbers ending in the last 4 digits, and then iterates the results, so it should be able to find the contacts...
    Kind regards.
  3. Sam Smith
    Dec 14, 2017
    11
    Per the title, we're using Client side. We have the search settings set to 9, as our contact database is large enough that four concurrent numbers are actually relatively common.
  4. edossantos
    Jun 27, 2007
    1,600
    125
    OK, thanks for the feedback. I had to ask anyway as the server side integration uses the Web client to show the contact records, so you always have a client side... So it's better to re-confirm to properly troubleshoot...
    The MaxCompareLength setting will not change the plugin behavior. That setting will be used to decide which contact is a match. But the initial lookup will consider the last 4 digits, and this is in order to avoid problems with spaces, dashes, etc. as Salesforce stores numbers as strings, and if you try to do the lookup with the entire number you will not have a match...
    Did you check the logs from "%AppData%\3CXPhone for Windows\Logs"? Maybe there you have information on why the lookup is failing.
    Kind regards.
  5. Sam Smith
    Dec 14, 2017
    11
    Appreciate the help. I'll keep an eye on the logs. FYI, if the lookup is starting from the last four, is it smart enough to ignore ext####?
  6. edossantos
    Jun 27, 2007
    1,600
    125
    You have a setting in 3CXPhone > Settings > Advanced > Integration > General, to only consider numbers with length greater than X digits. So if you configure that setting, you can ignore calls from internal extensions.
  7. Sam Smith
    Dec 14, 2017
    11
    That's not what I'm referring to. In Salesforce, we store numbers with extensions as 555-555-5555x123
  8. edossantos
    Jun 27, 2007
    1,600
    125
    Ah, sorry, I misunderstood you. No, in that case the plugin will not be able to find the contact...
