Salesforce - creating lead record on inbound call.
Discussion in 'CRM / Helpdesk / App Integration' started by Myles_G94, Oct 2, 2017.
  1. Myles_G94
    Aug 17, 2017
    6
    Hi All,
    I have set up the Salesforce integration so 3CX looks for existing leads and creates a task to log the inbound call on that lead, which works fine.
    However, is there a way that when an inbound call takes place and a lead record is not found, it creates the task anyway so we can track all incoming calls via reporting on Salesforce.
    We do not want to use the "Create Contact if not known" as contacts are completely unrelated to our lead object.
    We do not necessarily need a lead record creating; just the task within salesforce to prove there was an inbound call from an unknown source.
    Thanks for all your help!
    Myles
  2. Andreas Paradisiotis
    Apr 7, 2017
    53
    11
    Hello Myles_G94
    You can customize the existing salesforce plugin and with few lines of code you can made it.
    The plugin is located where 3cx client is installed into this path C:\ProgramData\3CXPhone for Windows\PhoneApp\DotNetScripts\Salesforce
    Open the solution and make the modifications. Then upload it to management console in the integration section and assign your custom plugin to the extensions that you need.
    Here some documents to get started with the development of a custom plugin
    https://www.3cx.com/docs/crm-integration/
    https://www.3cx.com/blog/docs/3cxphone-for-windows-api/
