Salesforce Integration Authentication
Discussion in 'CRM / Helpdesk / App Integration' started by cakahl, Apr 5, 2017.
  1. cakahl
    Jul 14, 2016
    Our organization uses a custom Salesforce URL for user authentication through SSO. It looks like the integration uses the standard Salesforce login flow. Is there a way to customize this?
  2. edossantos
    edossantos Support Team
    Jun 27, 2007
    1,605
    126
    Hi @cakahl,
    We provide the integration with Salesforce as a C# script. You can take it (install it for an extension) and make all the changes you need. When you have it ready, you can upload it to 3CX as a custom plug-in, as explained here:
    https://www.3cx.com/blog/releases/crm-integration-diy/
    Kind regards.
