Salesforce integration
Discussion in '3CX Phone System - General' started by Flash99, Mar 1, 2018.
  1. Flash99
    Aug 3, 2017
    98
    8
    I'm looking to integrate 3CX with Salesforce
    Specificly I need the option to log calls in Salesforce
    I found how to do the server side and client side integrations, but I still not sure what type of integration I need or maybe I need both of them ?
  2. Saqqara
    Saqqara Well-Known Member
    Mar 12, 2014
    1,248
    202
  3. Flash99
    Aug 3, 2017
    98
    8
    Yes I did, but as I mentioned before I'm not sure what will it give in terms of features
    I belive it will allow to see contact info, but I don't think it will allow Salesforce call logging
    And if I'm right then if for logging I need to do client side integration then do I need to do both or client side is enought ?
  4. lneblett
    lneblett Well-Known Member
    Sep 7, 2010
    2,086
    64
    Follow the instructions. What you seek for call logging is "journaling". From within 3CX go to Settings, CRM and select Salesforce. Once installed, then go to the integration tab for each extension needing it and select Salesforce. Each extension/user will need to use the softphone and once the aforementioned has been done, then they will need to exit the softphone and restart same thereby causing the softphone to reprovision and pickup the Salesforce integration. Once done, then from within the softphone go to the settings and select Advanced and Integration. Start with the general tab as this is where journaling is located along with some of the basics. Once set, then edit Salesforce to your needs.
  5. Flash99
    Aug 3, 2017
    98
    8
    If I follow this "From within 3CX go to Settings, CRM and select Salesforce" I have Server Side and Client side. My main question is do I need both of them or just one of them and what is the difference between them in terms of features?
  6. Saqqara
    Mar 12, 2014
    1,248
    202
  7. lneblett
    Sep 7, 2010
    2,086
    64
    You only need one. As far as I know there is no loss of functionality between the two methods. Server side seems to allow a common log-in using the name you created when doing the integration and therefore eases the provisioning task. Client side allows for each user to use their log in. You must also have Salesforce up and running on the users' PCs.
