Salesforce Open CTI Integration with 3CX
Discussion in 'CRM / Helpdesk / App Integration' started by Garima Kour, Aug 28, 2017.
  1. Garima Kour
    Aug 28, 2017
    I want to integrate Salesforce Open CTI with 3CX. For this I need the 3CX API documentation. Also, if anyone is aware what are the other prerequisites to start the same like Provider Account, Provider Auth Token, endpoint etc.
    Appreciate your inputs on this.
    Thanks,
    Garima
