Same DID/inbound rule on two (or more) different gateways
Discussion in 'Ideas' started by echoinformatica, Nov 21, 2016.
Same DID/inbound rule on two (or more) different gateways 5 5 1votes
5/5, 1 vote
  1. echoinformatica
    Aug 8, 2016
    6
    7
    in case you have two gateways with identical DIDs such issue may arise indeed, which is related to identifying the source of the calls.
    What you could do however is to fake an extra digit infront of each DID presented by the second gateway, with a manipulation made at the gateway config file level.
    Actually this occurs because with gateways you don't have Source identification settings as in Trunks.
    With 2 trunks of same sip server you would apply source identification on one of the fields which provide something unique such as an authentication number.
    If there was a source identification section in the inbound parameters of the gateways you could have filtered on the gateway host/port variable in one of the fields as INVIT|E from gw1 vs gw2 have different host.
    Thanks.
  2. the60
    the60 New Member
    Oct 21, 2011
    117
    50
    We experienced big problems when setting up our provider's backup trunk IPs in 3CX. Our provider gives us multiple IPs to peer with, for origination & termination. 3CX does not inherently handle this very well.
