Samsung Galaxy S3 problem
Discussion in 'Android' started by igpetkov, Dec 25, 2015.
  1. igpetkov
    Feb 25, 2015
    25
    Hi, all
    I have a problem with Samsung Galaxy S3 - Android version 4.2
    I send config e-mail from 3CX , client receive it, open link and install 3cx phone ver.14, then download config file, but cant open it. I try with diffrent explorers, but the result is the same. Can someone help me. Thanks.
    P.S. when I send config e-mails to other clients (with other phones) everything works fine
    11,084
    325
    Did you come across this?
    http://www.3cx.com/forums/post175991.html?hilit=can%27t%20open%20attachment#p175991
  3. igpetkov
    Feb 25, 2015
    25
    Thank you, I will try another file explorer and write down result , but maybe on Monday, cause it is my client phone
    Thanks again
  4. Rudedog
    Dec 23, 2016
    I know this is an old post but I just came across it after installing a 3CX server at home. I tried to use my S3 for testing and found I had the same issue opening up the registration file. I discovered that Total Commander file manager did recognize it and the 3CX client picked the registration file right up after tapping on it. Hope this may help someone facing the same issue.
