Samsung Galaxy S4 cannot connect over 3g, 4g or lte
Discussion in 'Android' started by patrickrivard, Sep 14, 2013.
  1. patrickrivard
    patrickrivard New Member
    May 29, 2008
    100
    I used to be able to connect over 3g but no longer since last update.
    Anyone else has the same issue?
  2. arthur30
    Sep 16, 2013
    have you switched to a different mobile service provider, may be you need to the settings from the service provider again.
  3. patrickrivard
    May 29, 2008
    100
    Did not...
    does it work for you? With all the latest versions.
  4. ian.watts
    ian.watts Active Member
    Apr 8, 2011
    532
    v12 on my GS3 works over 3G still. I keep forgetting to logout of my service desk queue.. annoying when I'm on the road and those queue calls ring me. :p
  5. rjhsystems
    Sep 11, 2013
    6
    there is an option in the app to Enable 3G make sure that is checked
  6. leejor
    10,737
    278
    I've had no issues over 3G (HSPA/HSPA+), or 4G (LTE) networks with any of the recent versions
  7. patrickrivard
    May 29, 2008
    100
    V12.0.53-registering via cell network
    Since There were no logical explanation to this issue yet, I'm posting the info required to troubleshoot...
    Device Info
    Phone Model: Samsung Galaxy S4 (SGH-1337M)
    Firmware Version: [4.2.2]
    Issue Info
    Connection: [3G]
    Server: [External]
    This version of 3cx on Android works great over WiFi, but will not register over a cellular network, any of them...
    Earlier versions use to work, but not this one...
    Thank you for any help
    Patrick Rivrad
