Samsung Galaxy SL - I can hear the caller but can't talk?
Discussion in 'Android' started by dn29, Jul 13, 2011.
  1. dn29
    Jul 13, 2011
    *Samsung Galaxy SL problem
    >I can make a call and hear the person I am calling but they can't hear me (this only happens when using VOIP)
  2. KerryG
    KerryG Active Member
    Jun 19, 2009
    960
    Re: Samsung Galaxy SL - I can hear the caller but can't talk
    Using Wifi or 3G? 3G has a lot of issues with voip calls.
  3. dn29
    Jul 13, 2011
    I am using Wifi.
    When I do VOIP calls its like the mic of the phone does not work.
  4. leejor
    11,263
    358
    Are you using this with 3CX PBX, or a VoIP provider?
  5. dn29
    Jul 13, 2011
    I am using it with a VOIP provider (callcentric and ipkall). I tried using this app with a newer phone (Galaxy S II) and an older phone (HTC Wildfire) ; it worked fine with those phones except my Galaxy SL. :(
  6. leejor
    11,263
    358
    It sounds then, like an issue (setting/option/incompatibility?) with that one particular phone. Unless someone is using the same model, and has a solution, you may be out of luck until, perhaps, the next release.
  7. dn29
    Jul 13, 2011
    Next release of 3CX or a new firmware for the phone :?:
    TY :D
  8. abdallaramadan
    Aug 30, 2011
    I am having exactly the same problem with samsung galaxy SL. I hope this can be fixed.
    Thanks 3CX. :)
  9. leejor
    11,263
    358
    Did you try to manually download, and install, the most recent (Tunnel version) release?
  10. abdallaramadan
    Aug 30, 2011
    Thank you for your reply, but where can I download that "tunnel version" release?
  11. Vali_3CX
    Vali_3CX Well-Known Member
    Dec 12, 2008
    1,533
    71
    http://www.3cx.com/forums/new-3cxphone-phone-for-android-with-tunnel-21325.html
