Sangoma 102 Netborder Express Error after Upgrade to V11 SP4
Discussion in '3CX Phone System - General' started by west2, Feb 12, 2013.
  1. west2
    Mar 1, 2012
    7
    I am running 3cx V11 SP3 on a windows 2008r2 server.
    Before installing SP4 Sangoma 102 called out fine.
    After installing SP4 last night, I can no longer make out bound calls with the Sangoma 102d / Netborder Express.
    I regenerate the config file in 3cx and loaded to NBE gateway manager, but no change.
    3CX log: (Error in 1st line)
    12-Feb-2013 13:56:18.974 Call to T:Line:10017>>8067740146@[Dev:sip:10017@10.9.25.82:5066,Dev:sip:10016@10.9.25.82:5066] from L:1956.1[Extn] failed, cause: Cause: 503 Service Unavailable/INVITE from 10.9.25.82:5066
    12-Feb-2013 13:56:18.908 [CM503025]: Call(C:1956): Calling T:Line:10017>>8067740146@[Dev:sip:10017@10.9.25.82:5066,Dev:sip:10016@10.9.25.82:5066] for L:1956.1[Extn]
    12-Feb-2013 13:56:18.860 [CM503027]: Call(C:1956): From: Extn:101 ("8062936075" <sip:101@10.9.25.82:5060>) to T:Line:10008>>97740146@[Dev:sip:10008@10.9.27.252:5066,Dev:sip:10007@10.9.27.252:5064,Dev:sip:10006@10.9.27.252:5062,Dev:sip:10005@10.9.27.252:5060]
    12-Feb-2013 13:56:18.860 [CM503004]: Call(C:1956): Route 3: from L:1956.1[Extn] to T:Line:10008>>97740146@[Dev:sip:10008@10.9.27.252:5066,Dev:sip:10007@10.9.27.252:5064,Dev:sip:10006@10.9.27.252:5062,Dev:sip:10005@10.9.27.252:5060]
    12-Feb-2013 13:56:18.860 [CM503027]: Call(C:1956): From: Extn:101 ("8062936075" <sip:101@10.9.25.82:5060>) to T:Line:10003>>97740146@[Dev:sip:10003@10.9.27.251:5066,Dev:sip:10002@10.9.27.251:5064,Dev:sip:10001@10.9.27.251:5062,Dev:sip:10000@10.9.27.251:5060]
    12-Feb-2013 13:56:18.860 [CM503004]: Call(C:1956): Route 2: from L:1956.1[Extn] to T:Line:10003>>97740146@[Dev:sip:10003@10.9.27.251:5066,Dev:sip:10002@10.9.27.251:5064,Dev:sip:10001@10.9.27.251:5062,Dev:sip:10000@10.9.27.251:5060]
    12-Feb-2013 13:56:18.860 [CM503027]: Call(C:1956): From: Extn:101 ("8062936075" <sip:101@10.9.25.82:5060>) to T:Line:10017>>8067740146@[Dev:sip:10017@10.9.25.82:5066,Dev:sip:10016@10.9.25.82:5066]
    12-Feb-2013 13:56:18.860 [CM503004]: Call(C:1956): Route 1: from L:1956.1[Extn] to T:Line:10017>>8067740146@[Dev:sip:10017@10.9.25.82:5066,Dev:sip:10016@10.9.25.82:5066]
    12-Feb-2013 13:56:18.860 Call(C:1956): Call from Extn:101 to 7740146 matches outbound rule 'Local 2'
    12-Feb-2013 13:56:18.858 [CM503001]: Call(C:1956): Incoming call from Extn:101 to <sip:7740146@10.9.25.82:5060>
    12-Feb-2013 13:56:18.857 NAT/ALG check:L:1956.1[Extn] REQUEST 'INVITE' - basic check passed. No information for extended checks
  2. kevin
    kevin Member
    Nov 23, 2006
    316
    Re: Sangoma 102 Netborder Express Error after Upgrade to V11
    Hi there
    The main hint here is in this log message:
    The "503 Service Unavailable" message *typically* means that the device cannot process the request because of some internal failure.
    Your next step is to invoke Sangoma support to understand the cause for their device to generate this message.
  3. west2
    Mar 1, 2012
    7
    I have gotten the calls to complete and now get inbound and outbound calling.
    Now I get intermittent 1 way audio. It is always no outbound audio. But either inbound or outbound calls.
    When the Gateway setting PBX delivers audio is unchecked, caller get holds music if placed on park, but not phone audio. When it is checked. they hear no call audio or hold music.
    In trying to find a common link, I checked/unchecked the PBX Delivers audio box several time. The last time I left it unchecked and saved and I now get completely functional 2-way audio.
  4. kevin
    kevin Member
    Nov 23, 2006
    316
    Glad you got things working.
    I would not make changes while things are working fine, but, for the record, the most compatible combination to fall back to would be:
    PBX Delivers Audio = Enabled
    Supports ReINVITES = Disabled
    Supports Replaces = Disabled
    ...when you are having issues..
