- Joined
- Feb 23, 2012
- Messages
- 213
- Reaction score
- 0
HI,
Anyone resolve the sangoma issue that is not synch with 3cx? i don't have a netboard express license.txt.sig is this important on the configuration?
here is the 3cx log when i try calling the line
18:13:57.632 [CM504002]: Ext.341: a contact is unregistered. Contact(s): []
18:09:18.282 [CM504001]: Ext.311: new contact is registered. Contact(s): [sip:[email protected]:5065;ob/311]
18:02:12.736 [CM503008]: Call(27): Call is terminated
18:02:05.595 [CM503007]: Call(27): Device joined: sip:[email protected]:40600;rinstance=72553b3fba268ad4
18:02:05.593 [CM503007]: Call(27): Device joined: sip:69.94.226.174:5060
18:02:05.590 [CM503002]: Call(27): Alerting sip:[email protected]:40600;rinstance=72553b3fba268ad4
18:02:05.443 [CM503025]: Call(27): Calling Unknown:Ext.EndCall@[Dev:sip:[email protected]:40600;rinstance=72553b3fba268ad4]
18:02:05.428 [CM503016]: Call(27): Attempt to reach <sip:119.93.230.156:5060;user=endcall> failed. Reason: Busy
18:02:05.428 [CM503010]: Making route(s) to <sip:119.93.230.156:5060;user=endcall>
18:02:05.427 [CM505003]: Provider:[Accela#69] Device info: Device Not Identified: User Agent not matched; Capabilities:[reinvite, replaces, able-no-sdp, recvonly] UserAgent: [] PBX contact: [sip:119.93.230.156:5060]
18:02:05.422 [CM503001]: Call(27): Incoming call from 0386722400@(Ln.10003@Accela#69) to <sip:119.93.230.156:5060;user=endcall>
18:02:05.190 [CM503012]: Inbound any hours rule (AUS-61390084239) for 10003 forwards to DN:
17:59:52.511 [CM503008]: Call(26): Call is terminated
17:59:50.678 Currently active calls - 1: [26]
17:59:45.298 [CM503007]: Call(26): Device joined: sip:[email protected]:40600;rinstance=72553b3fba268ad4
17:59:45.296 [CM503007]: Call(26): Device joined: sip:69.94.226.174:5060
17:59:45.293 [CM503002]: Call(26): Alerting sip:[email protected]:40600;rinstance=72553b3fba268ad4
17:59:45.159 [CM503025]: Call(26): Calling Unknown:Ext.EndCall@[Dev:sip:[email protected]:40600;rinstance=72553b3fba268ad4]
17:59:45.127 [CM503016]: Call(26): Attempt to reach <sip:119.93.230.156:5060;user=endcall> failed. Reason: Busy
17:59:45.127 [CM503010]: Making route(s) to <sip:119.93.230.156:5060;user=endcall>
17:59:45.126 [CM505003]: Provider:[Accela#69] Device info: Device Not Identified: User Agent not matched; Capabilities:[reinvite, replaces, able-no-sdp, recvonly] UserAgent: [] PBX contact: [sip:119.93.230.156:5060]
17:59:45.125 [CM503001]: Call(26): Incoming call from 0419095272@(Ln.10003@Accela#69) to <sip:119.93.230.156:5060;user=endcall>
17:59:44.894 [CM503012]: Inbound any hours rule (AUS-61390084239) for 10003 forwards to DN:
17:59:01.967 [CM503008]: Call(25): Call is terminated
17:58:54.766 [CM503007]: Call(25): Device joined: sip:[email protected]:40600;rinstance=72553b3fba268ad4
17:58:54.764 [CM503007]: Call(25): Device joined: sip:69.94.226.174:5060
17:58:54.761 [CM503002]: Call(25): Alerting sip:[email protected]:40600;rinstance=72553b3fba268ad4
17:58:54.615 [CM503025]: Call(25): Calling Unknown:Ext.EndCall@[Dev:sip:[email protected]:40600;rinstance=72553b3fba268ad4]
17:58:54.606 [CM503016]: Call(25): Attempt to reach <sip:119.93.230.156:5060;user=endcall> failed. Reason: Busy
17:58:54.606 [CM503010]: Making route(s) to <sip:119.93.230.156:5060;user=endcall>
17:58:54.605 [CM505003]: Provider:[Accela#69] Device info: Device Not Identified: User Agent not matched; Capabilities:[reinvite, replaces, able-no-sdp, recvonly] UserAgent: [] PBX contact: [sip:119.93.230.156:5060]
17:58:54.593 [CM503001]: Call(25): Incoming call from 0419095272@(Ln.10003@Accela#69) to <sip:119.93.230.156:5060;user=endcall>
17:58:54.362 [CM503012]: Inbound any hours rule (AUS-61390084239) for 10003 forwards to DN:
17:57:38.512 [CM503008]: Call(24): Call is terminated
17:57:31.312 [CM503007]: Call(24): Device joined: sip:[email protected]:40600;rinstance=72553b3fba268ad4
17:57:31.309 [CM503007]: Call(24): Device joined: sip:69.94.226.174:5060
17:57:31.306 [CM503002]: Call(24): Alerting sip:[email protected]:40600;rinstance=72553b3fba268ad4
17:57:31.180 [CM503025]: Call(24): Calling Unknown:Ext.EndCall@[Dev:sip:[email protected]:40600;rinstance=72553b3fba268ad4]
17:57:31.164 [CM503016]: Call(24): Attempt to reach <sip:119.93.230.156:5060;user=endcall> failed. Reason: Busy
17:57:31.164 [CM503010]: Making route(s) to <sip:119.93.230.156:5060;user=endcall>
17:57:31.163 [CM505003]: Provider:[Accela#69] Device info: Device Not Identified: User Agent not matched; Capabilities:[reinvite, replaces, able-no-sdp, recvonly] UserAgent: [] PBX contact: [sip:119.93.230.156:5060]
17:57:31.158 [CM503001]: Call(24): Incoming call from 0386722400@(Ln.10003@Accela#69) to <sip:119.93.230.156:5060;user=endcall>
17:57:30.927 [CM503012]: Inbound any hours rule (AUS-61390084239) for 10003 forwards to DN:
17:57:26.954 [CM504002]: Ext.311: a contact is unregistered. Contact(s): []
17:56:40.452 [CM503008]: Call(23): Call is terminated
17:56:33.251 [CM503007]: Call(23): Device joined: sip:[email protected]:40600;rinstance=72553b3fba268ad4
17:56:33.249 [CM503007]: Call(23): Device joined: sip:69.94.226.174:5060
17:56:33.246 [CM503002]: Call(23): Alerting sip:[email protected]:40600;rinstance=72553b3fba268ad4
17:56:33.097 [CM503025]: Call(23): Calling Unknown:Ext.EndCall@[Dev:sip:[email protected]:40600;rinstance=72553b3fba268ad4]
17:56:33.082 [CM503016]: Call(23): Attempt to reach <sip:119.93.230.156:5060;user=endcall> failed. Reason: Busy
17:56:33.082 [CM503010]: Making route(s) to <sip:119.93.230.156:5060;user=endcall>
17:56:33.081 [CM505003]: Provider:[Accela#69] Device info: Device Not Identified: User Agent not matched; Capabilities:[reinvite, replaces, able-no-sdp, recvonly] UserAgent: [] PBX contact: [sip:119.93.230.156:5060]
17:56:33.076 [CM503001]: Call(23): Incoming call from 0434656383@(Ln.10003@Accela#69) to <sip:119.93.230.156:5060;user=endcall>
17:56:32.844 [CM503012]: Inbound any hours rule (AUS-61390084239) for 10003 forwards to DN:
17:55:22.550 [CM503008]: Call(22): Call is terminated
17:55:17.045 [CM503008]: Call(21): Call is terminated
17:55:15.319 [CM503007]: Call(22): Device joined: sip:[email protected]:40600;rinstance=72553b3fba268ad4
17:55:15.317 [CM503007]: Call(22): Device joined: sip:69.94.226.174:5060
17:55:15.314 [CM503002]: Call(22): Alerting sip:[email protected]:40600;rinstance=72553b3fba268ad4
17:55:15.116 [CM503025]: Call(22): Calling Unknown:Ext.EndCall@[Dev:sip:[email protected]:40600;rinstance=72553b3fba268ad4]
17:55:15.091 [CM503016]: Call(22): Attempt to reach <sip:119.93.230.156:5060;user=endcall> failed. Reason: Busy
17:55:15.091 [CM503010]: Making route(s) to <sip:119.93.230.156:5060;user=endcall>
17:55:15.090 [CM505003]: Provider:[Accela#69] Device info: Device Not Identified: User Agent not matched; Capabilities:[reinvite, replaces, able-no-sdp, recvonly] UserAgent: [] PBX contact: [sip:119.93.230.156:5060]
17:55:15.085 [CM503001]: Call(22): Incoming call from 0434656383@(Ln.10003@Accela#69) to <sip:119.93.230.156:5060;user=endcall>
17:55:14.850 [CM503012]: Inbound any hours rule (AUS-61390084239) for 10003 forwards to DN:
17:55:12.045 [CM503007]: Call(21): Device joined: sip:[email protected]:40600;rinstance=72553b3fba268ad4
17:55:12.043 [CM503007]: Call(21): Device joined: sip:[email protected]:5065;ob
17:55:12.040 [CM503002]: Call(21): Alerting sip:[email protected]:40600;rinstance=72553b3fba268ad4
17:55:11.893 [CM503025]: Call(21): Calling Unknown:Ext.EndCall@[Dev:sip:[email protected]:40600;rinstance=72553b3fba268ad4]
17:55:11.856 [CM503016]: Call(21): Attempt to reach <sip:[email protected]:5060> failed. Reason: Not Registered
17:55:11.855 [CM503016]: Call(21): Attempt to reach <sip:[email protected]:5060> failed. Reason: Not Registered
17:55:11.855 [CM503017]: Call(21): Target is not registered: Out.97729000{rule=Rule for data1}
17:55:11.851 [CM503010]: Making route(s) to <sip:[email protected]:5060>
17:55:11.850 [CM505001]: Ext.311: Device info: Device Not Identified: User Agent not matched; Capabilities:[reinvite, replaces, able-no-sdp, recvonly] UserAgent: [3CXPhone for iPhone 1.1.5] PBX contact: [sip:[email protected]:5060]
17:55:11.847 [CM503001]: Call(21): Incoming call from Ext.311 to <sip:[email protected]:5060>
17:54:36.165 [CM503008]: Call(20): Call is terminated
17:54:28.962 [CM503007]: Call(20): Device joined: sip:[email protected]:40600;rinstance=72553b3fba268ad4
17:54:28.960 [CM503007]: Call(20): Device joined: sip:69.94.226.174:5060
17:54:28.957 [CM503002]: Call(20): Alerting sip:[email protected]:40600;rinstance=72553b3fba268ad4
17:54:28.811 [CM503025]: Call(20): Calling Unknown:Ext.EndCall@[Dev:sip:[email protected]:40600;rinstance=72553b3fba268ad4]
17:54:28.796 [CM503016]: Call(20): Attempt to reach <sip:119.93.230.156:5060;user=endcall> failed. Reason: Busy
17:54:28.796 [CM503010]: Making route(s) to <sip:119.93.230.156:5060;user=endcall>
17:54:28.795 [CM505003]: Provider:[Accela#69] Device info: Device Not Identified: User Agent not matched; Capabilities:[reinvite, replaces, able-no-sdp, recvonly] UserAgent: [] PBX contact: [sip:119.93.230.156:5060]
17:54:28.790 [CM503001]: Call(20): Incoming call from 0434656383@(Ln.10003@Accela#69) to <sip:119.93.230.156:5060;user=endcall>
17:54:28.558 [CM503012]: Inbound any hours rule (AUS-61390084239) for 10003 forwards to DN:
17:51:14.494 [CM503008]: Call(19): Call is terminated
17:51:07.293 [CM503007]: Call(19): Device joined: sip:[email protected]:40600;rinstance=72553b3fba268ad4
17:51:07.291 [CM503007]: Call(19): Device joined: sip:69.94.226.174:5060
17:51:07.288 [CM503002]: Call(19): Alerting sip:[email protected]:40600;rinstance=72553b3fba268ad4
17:51:07.141 [CM503025]: Call(19): Calling Unknown:Ext.EndCall@[Dev:sip:[email protected]:40600;rinstance=72553b3fba268ad4]
17:51:07.126 [CM503016]: Call(19): Attempt to reach <sip:119.93.230.156:5060;user=endcall> failed. Reason: Busy
17:51:07.126 [CM503010]: Making route(s) to <sip:119.93.230.156:5060;user=endcall>
17:51:07.125 [CM505003]: Provider:[Accela#69] Device info: Device Not Identified: User Agent not matched; Capabilities:[reinvite, replaces, able-no-sdp, recvonly] UserAgent: [] PBX contact: [sip:119.93.230.156:5060]
17:51:07.120 [CM503001]: Call(19): Incoming call from 0386722400@(Ln.10003@Accela#69) to <sip:119.93.230.156:5060;user=endcall>
17:51:06.888 [CM503012]: Inbound any hours rule (AUS-61390084239) for 10003 forwards to DN:
17:50:59.954 [CM503008]: Call(18): Call is terminated
17:50:54.641 Currently active calls - 1: [18]
17:50:52.752 [CM503007]: Call(18): Device joined: sip:[email protected]:40600;rinstance=72553b3fba268ad4
17:50:52.750 [CM503007]: Call(18): Device joined: sip:69.94.226.174:5060
17:50:52.747 [CM503002]: Call(18): Alerting sip:[email protected]:40600;rinstance=72553b3fba268ad4
17:50:52.599 [CM503025]: Call(18): Calling Unknown:Ext.EndCall@[Dev:sip:[email protected]:40600;rinstance=72553b3fba268ad4]
17:50:52.581 [CM503016]: Call(18): Attempt to reach <sip:119.93.230.156:5060;user=endcall> failed. Reason: Busy
17:50:52.581 [CM503010]: Making route(s) to <sip:119.93.230.156:5060;user=endcall>
17:50:52.580 [CM505003]: Provider:[Accela#69] Device info: Device Not Identified: User Agent not matched; Capabilities:[reinvite, replaces, able-no-sdp, recvonly] UserAgent: [] PBX contact: [sip:119.93.230.156:5060]
17:50:52.575 [CM503001]: Call(18): Incoming call from 0402830617@(Ln.10003@Accela#69) to <sip:119.93.230.156:5060;user=endcall>
17:50:51.877 [CM503012]: Inbound any hours rule (AUS-61390084239) for 10003 forwards to DN:
17:49:32.894 [CM504002]: Ext.379: a contact is unregistered. Contact(s): []
17:45:30.156 [CM504002]: Ext.336: a contact is unregistered. Contact(s): []
17:45:04.476 [CM503008]: Call(17): Call is terminated
17:45:01.130 [CM504001]: Ext.311: new contact is registered. Contact(s): [sip:[email protected]:5065;ob/311]
17:44:36.712 [CM503007]: Call(17): Device joined: sip:[email protected]:4096;rinstance=c6d5b3bd7e8c9c7f
17:44:36.711 [CM503007]: Call(17): Device joined: sip:[email protected]:3653;rinstance=0ed789e7b5ab0d76
17:44:36.611 Currently active calls - 1: [17]
17:44:34.291 [CM505001]: Ext.336: Device info: Device Not Identified: User Agent not matched; Capabilities:[reinvite, replaces, able-no-sdp, recvonly] UserAgent: [3CXPhone 6.0.20943.0] PBX contact: [sip:[email protected]:5060]
17:44:34.291 [CM503002]: Call(17): Alerting sip:[email protected]:4096;rinstance=c6d5b3bd7e8c9c7f
17:44:34.142 [CM503025]: Call(17): Calling Ext:Ext.336@[Dev:sip:[email protected]:4096;rinstance=c6d5b3bd7e8c9c7f]
17:44:34.095 [CM503004]: Call(17): Route 1: Ext:Ext.336@[Dev:sip:[email protected]:4096;rinstance=c6d5b3bd7e8c9c7f]
17:44:34.095 [CM503010]: Making route(s) to <sip:[email protected]:5060>
17:44:34.094 [CM505001]: Ext.340: Device info: Device Not Identified: User Agent not matched; Capabilities:[reinvite, replaces, able-no-sdp, recvonly] UserAgent: [3CXPhone 6.0.20943.0] PBX contact: [sip:[email protected]:5060]
17:44:34.091 [CM503001]: Call(17): Incoming call from Ext.340 to <sip:[email protected]:5060>
17:44:27.046 [CM503008]: Call(16): Call is terminated
17:44:25.340 [CM503007]: Call(16): Device joined: sip:[email protected]:4096;rinstance=c6d5b3bd7e8c9c7f
17:44:25.339 [CM503007]: Call(16): Device joined: sip:[email protected]:3653;rinstance=0ed789e7b5ab0d76
17:44:22.818 [CM505001]: Ext.336: Device info: Device Not Identified: User Agent not matched; Capabilities:[reinvite, replaces, able-no-sdp, recvonly] UserAgent: [3CXPhone 6.0.20943.0] PBX contact: [sip:[email protected]:5060]
17:44:22.818 [CM503002]: Call(16): Alerting sip:[email protected]:4096;rinstance=c6d5b3bd7e8c9c7f
17:44:22.618 [CM503025]: Call(16): Calling Ext:Ext.336@[Dev:sip:[email protected]:4096;rinstance=c6d5b3bd7e8c9c7f]
17:44:22.605 [CM503004]: Call(16): Route 1: Ext:Ext.336@[Dev:sip:[email protected]:4096;rinstance=c6d5b3bd7e8c9c7f]
17:44:22.605 [CM503010]: Making route(s) to <sip:[email protected]:5060>
17:44:22.604 [CM505001]: Ext.340: Device info: Device Not Identified: User Agent not matched; Capabilities:[reinvite, replaces, able-no-sdp, recvonly] UserAgent: [3CXPhone 6.0.20943.0] PBX contact: [sip:[email protected]:5060]
17:44:22.603 [CM503001]: Call(16): Incoming call from Ext.340 to <sip:[email protected]:5060>
17:43:10.166 [CM503008]: Call(15): Call is terminated
17:43:08.770 [CM503007]: Call(15): Device joined: sip:[email protected]:40600;rinstance=0e3b3bbe6eee1649
17:43:08.768 [CM503007]: Call(15): Device joined: sip:[email protected]:4096;rinstance=c6d5b3bd7e8c9c7f
17:43:08.765 [CM505001]: Ext.999: Device info: Device Identified: [Man: 3CX Ltd.;Mod: Voice Mail Menu;Rev: General] Capabilities:[reinvite, replaces, able-no-sdp, recvonly] UserAgent: [3CX Voice Mail Menu] PBX contact: [sip:[email protected]:5060]
17:43:08.765 [CM503002]: Call(15): Alerting sip:[email protected]:40600;rinstance=0e3b3bbe6eee1649
17:43:08.567 [CM503025]: Call(15): Calling Ext:Ext.999@[Dev:sip:[email protected]:40600;rinstance=0e3b3bbe6eee1649]
17:43:08.518 [CM503005]: Call(15): Forwarding: Ext:Ext.999@[Dev:sip:[email protected]:40600;rinstance=0e3b3bbe6eee1649]
17:43:08.513 [CM503003]: Call(15): Call to sip:[email protected]:5060 has failed; Cause: 486 Busy Here; from IP:10.31.16.53:3653
17:43:08.512 [CM505001]: Ext.340: Device info: Device Not Identified: User Agent not matched; Capabilities:[reinvite, replaces, able-no-sdp, recvonly] UserAgent: [3CXPhone 6.0.20943.0] PBX contact: [sip:[email protected]:5060]
17:43:08.512 [CM503002]: Call(15): Alerting sip:[email protected]:3653;rinstance=0ed789e7b5ab0d76
17:43:08.341 [CM503025]: Call(15): Calling Ext:Ext.340@[Dev:sip:[email protected]:3653;rinstance=0ed789e7b5ab0d76]
17:43:08.295 [CM503004]: Call(15): Route 1: Ext:Ext.340@[Dev:sip:[email protected]:3653;rinstance=0ed789e7b5ab0d76]
17:43:08.295 [CM503010]: Making route(s) to <sip:[email protected]:5060>
17:43:08.294 [CM505001]: Ext.336: Device info: Device Not Identified: User Agent not matched; Capabilities:[reinvite, replaces, able-no-sdp, recvonly] UserAgent: [3CXPhone 6.0.20943.0] PBX contact: [sip:[email protected]:5060]
17:43:08.291 [CM503001]: Call(15): Incoming call from Ext.336 to <sip:[email protected]:5060>
17:42:40.524 [CM503003]: Call(14): Call to sip:[email protected]:5060 has failed; Cause: 487 Request Terminated; from IP:10.31.16.53:3653
17:42:40.325 [CM503008]: Call(14): Call is terminated
17:42:38.752 [CM505001]: Ext.340: Device info: Device Not Identified: User Agent not matched; Capabilities:[reinvite, replaces, able-no-sdp, recvonly] UserAgent: [3CXPhone 6.0.20943.0] PBX contact: [sip:[email protected]:5060]
17:42:38.752 [CM503002]: Call(14): Alerting sip:[email protected]:3653;rinstance=0ed789e7b5ab0d76
17:42:38.601 [CM503025]: Call(14): Calling Ext:Ext.340@[Dev:sip:[email protected]:3653;rinstance=0ed789e7b5ab0d76]
17:42:38.554 [CM503004]: Call(14): Route 1: Ext:Ext.340@[Dev:sip:[email protected]:3653;rinstance=0ed789e7b5ab0d76]
17:42:38.554 [CM503010]: Making route(s) to <sip:[email protected]:5060>
17:42:38.553 [CM505001]: Ext.336: Device info: Device Not Identified: User Agent not matched; Capabilities:[reinvite, replaces, able-no-sdp, recvonly] UserAgent: [3CXPhone 6.0.20943.0] PBX contact: [sip:[email protected]:5060]
17:42:38.551 [CM503001]: Call(14): Incoming call from Ext.336 to <sip:[email protected]:5060>
17:42:32.008 [CM503008]: Call(13): Call is terminated
17:42:30.603 Currently active calls - 1: [13]
17:42:25.469 [CM503007]: Call(13): Device joined: sip:[email protected]:4096;rinstance=c6d5b3bd7e8c9c7f
17:42:25.467 [CM503007]: Call(13): Device joined: sip:[email protected]:3653;rinstance=0ed789e7b5ab0d76
17:42:23.860 [CM505001]: Ext.336: Device info: Device Not Identified: User Agent not matched; Capabilities:[reinvite, replaces, able-no-sdp, recvonly] UserAgent: [3CXPhone 6.0.20943.0] PBX contact: [sip:[email protected]:5060]
17:42:23.860 [CM503002]: Call(13): Alerting sip:[email protected]:4096;rinstance=c6d5b3bd7e8c9c7f
17:42:23.708 [CM503025]: Call(13): Calling Ext:Ext.336@[Dev:sip:[email protected]:4096;rinstance=c6d5b3bd7e8c9c7f]
17:42:23.662 [CM503004]: Call(13): Route 1: Ext:Ext.336@[Dev:sip:[email protected]:4096;rinstance=c6d5b3bd7e8c9c7f]
17:42:23.661 [CM503010]: Making route(s) to <sip:[email protected]:5060>
17:42:23.661 [CM505001]: Ext.340: Device info: Device Not Identified: User Agent not matched; Capabilities:[reinvite, replaces, able-no-sdp, recvonly] UserAgent: [3CXPhone 6.0.20943.0] PBX contact: [sip:[email protected]:5060]
17:42:23.658 [CM503001]: Call(13): Incoming call from Ext.340 to <sip:[email protected]:5060>
17:42:19.100 [CM503003]: Call(12): Call to sip:[email protected]:5060 has failed; Cause: 487 Request Terminated; from IP:10.31.16.52:4096
17:42:18.901 [CM503008]: Call(12): Call is terminated
17:42:18.295 [CM505001]: Ext.336: Device info: Device Not Identified: User Agent not matched; Capabilities:[reinvite, replaces, able-no-sdp, recvonly] UserAgent: [3CXPhone 6.0.20943.0] PBX contact: [sip:[email protected]:5060]
17:42:18.295 [CM503002]: Call(12): Alerting sip:[email protected]:4096;rinstance=c6d5b3bd7e8c9c7f
17:42:18.146 [CM503025]: Call(12): Calling Ext:Ext.336@[Dev:sip:[email protected]:4096;rinstance=c6d5b3bd7e8c9c7f]
and here is the pbx configurator log in netboard express
2012-05-29 18:00:04:552 [868] INFO - netborder.pbxConfigurator : Creating Netborder Express Gateway configuration from C:\Program Files\Netborder\Express\Gateway\tmp\Sangoma_A101_E1_cfg
2012-05-29 18:00:04:575 [868] INFO - netborder.pbxConfigurator.PbxConverter.ExtractConfigData : Creating file gw.properties
2012-05-29 18:00:04:634 [868] INFO - netborder.pbxConfigurator.PbxConverter.ExtractConfigData : Creating file sip-client-registration.xml
2012-05-29 18:00:04:653 [868] INFO - netborder.pbxConfigurator.PbxConverter.ExtractConfigData : Creating file routing-rules.xml
2012-05-29 18:00:04:687 [868] INFO - netborder.pbxConfigurator.PbxConverter.ExtractConfigData : Creating file pstn-config.xml
2012-05-29 18:00:04:772 [868] INFO - netborder.smartUpdate.ConfigExporter : Creating archive at C:\Program Files\Netborder\Express\Gateway/pbx-configurator\Sangoma_A101_E1_cfg.zip
2012-05-29 18:00:04:783 [868] INFO - netborder.smartUpdate.ImportCfg : Beginning import process of config C:\Program Files\Netborder\Express\Gateway/pbx-configurator\Sangoma_A101_E1_cfg.zip
2012-05-29 18:00:04:877 [868] INFO - netborder.smartUpdate.ImportCfg : Configured service 'Netborder Express Gateway' to start automatically on start up.
2012-05-29 18:00:04:877 [868] INFO - netborder.smartUpdate.ImportCfg : Configured service 'Netborder Express Gateway' to restart automatically on failure.
2012-05-29 18:00:04:938 [868] INFO - netborder.smartUpdate.Converter.PropertiesConverter : Updating file(s) gw.properties from version 4.1.2 to version 4.1.3
2012-05-29 18:00:05:013 [868] INFO - netborder.smartUpdate.Converter.PropertiesConverter : Updating file(s) oamWebServer.properties from version 4.1.2 to version 4.1.3
2012-05-29 18:00:05:013 [868] INFO - netborder.smartUpdate.Converter.ValidationConverter : File C:\Program Files\Netborder\Express\Gateway/smart-update\tmpDir1\oamWebServer.properties does not exists
2012-05-29 18:00:05:013 [868] INFO - netborder.smartUpdate.Converter.XmlConverter : Updating file pstn-config.xml from version 4.1.2 to version 4.1.3
2012-05-29 18:00:05:048 [868] INFO - netborder.smartUpdate.Converter.PropertiesConverter : Updating file(s) oamWebServer.properties from version 4.1.3 to version 4.2.0
2012-05-29 18:00:05:048 [868] INFO - netborder.smartUpdate.Converter.ValidationConverter : File C:\Program Files\Netborder\Express\Gateway/smart-update\tmpDir2\oamWebServer.properties does not exists
2012-05-29 18:00:05:050 [868] INFO - netborder.smartUpdate.Converter.XmlConverter : Updating file pstn-config.xml from version 4.2.3 to version 4.3.0
2012-05-29 18:00:05:073 [868] INFO - netborder.smartUpdate.Converter.XmlConverter : Updating file pstn-config.xml from version 4.3.1 to version 4.3.2
2012-05-29 18:00:05:096 [868] INFO - netborder.smartUpdate.Converter.ValidationConverter : Validating files [pstn-config.xml] at version 4.3.2
2012-05-29 18:00:05:103 [868] INFO - netborder.smartUpdate.Converter.ValidationConverter : Validating files [gw.properties] at version 4.3.2
2012-05-29 18:00:05:103 [868] INFO - netborder.smartUpdate.Converter.ValidationConverter : saving properties file C:\Program Files\Netborder\Express\Gateway/pbx-configurator\tmpCfg1\gw.properties with documentation
2012-05-29 18:00:05:118 [868] INFO - netborder.smartUpdate.Converter.ValidationConverter : Validating files [oamWebServer.properties] at version 4.3.2
2012-05-29 18:00:05:119 [868] INFO - netborder.smartUpdate.Converter.ValidationConverter : File C:\Program Files\Netborder\Express\Gateway/smart-update\tmpDir1\oamWebServer.properties does not exists
2012-05-29 18:00:05:119 [868] INFO - netborder.smartUpdate.Converter.ValidationConverter : Validating files [wizard.properties] at version 4.3.2
2012-05-29 18:00:05:119 [868] INFO - netborder.smartUpdate.Converter.ValidationConverter : File C:\Program Files\Netborder\Express\Gateway/smart-update\tmpDir1\wizard.properties does not exists
2012-05-29 18:00:05:119 [868] INFO - netborder.smartUpdate.Converter.CopyConverter : Copying file dev-logger.properties
2012-05-29 18:00:05:119 [868] INFO - netborder.smartUpdate.Converter.CopyConverter : File C:\Program Files\Netborder\Express\Gateway/smart-update\tmpDir1\dev-logger.properties does not exists
2012-05-29 18:00:05:119 [868] INFO - netborder.smartUpdate.Converter.CopyConverter : Copying file prod-logger.properties
2012-05-29 18:00:05:119 [868] INFO - netborder.smartUpdate.Converter.CopyConverter : File C:\Program Files\Netborder\Express\Gateway/smart-update\tmpDir1\prod-logger.properties does not exists
2012-05-29 18:00:05:119 [868] INFO - netborder.smartUpdate.Converter.LicenseValidator : File C:\Program Files\Netborder\Express\Gateway/smart-update\tmpDir1\netborder-express-gateway-license.txt does not exists
2012-05-29 18:00:05:119 [868] INFO - netborder.smartUpdate.Converter.CopyConverter : Copying file oamWebServer.prod.cfg
2012-05-29 18:00:05:119 [868] INFO - netborder.smartUpdate.Converter.CopyConverter : File C:\Program Files\Netborder\Express\Gateway/smart-update\tmpDir1\oamWebServer.prod.cfg does not exists
2012-05-29 18:00:05:119 [868] INFO - netborder.smartUpdate.Converter.CopyConverter : Copying file oamWebServer-dev-logger.properties
2012-05-29 18:00:05:119 [868] INFO - netborder.smartUpdate.Converter.CopyConverter : File C:\Program Files\Netborder\Express\Gateway/smart-update\tmpDir1\oamWebServer-dev-logger.properties does not exists
2012-05-29 18:00:05:119 [868] INFO - netborder.smartUpdate.Converter.CopyConverter : Copying file oamWebServer-prod-logger.properties
2012-05-29 18:00:05:119 [868] INFO - netborder.smartUpdate.Converter.CopyConverter : File C:\Program Files\Netborder\Express\Gateway/smart-update\tmpDir1\oamWebServer-prod-logger.properties does not exists
2012-05-29 18:00:05:119 [868] INFO - netborder.smartUpdate.Converter.CopyConverter : Copying file fxo.conf
2012-05-29 18:00:05:119 [868] INFO - netborder.smartUpdate.Converter.CopyConverter : File C:\Program Files\Netborder\Express\Gateway/smart-update\tmpDir1\fxo.conf does not exists
2012-05-29 18:00:05:119 [868] INFO - netborder.smartUpdate.Converter.CopyConverter : Copying file routing-rules.xml
2012-05-29 18:00:05:122 [868] INFO - netborder.smartUpdate.Converter.CopyConverter : Copying file sip-client-registration.xml
2012-05-29 18:00:05:131 [868] INFO - netborder.smartUpdate.Converter.CopyConverter : Copying file sip-response-isdn-cause-mapping-ocs.xml
2012-05-29 18:00:05:131 [868] INFO - netborder.smartUpdate.Converter.CopyConverter : File C:\Program Files\Netborder\Express\Gateway/smart-update\tmpDir1\sip-response-isdn-cause-mapping-ocs.xml does not exists
2012-05-29 18:00:05:132 [868] INFO - netborder.smartUpdate.Converter.CopyConverter : Copying file sip-response-isdn-cause-mapping-rfc3398.xml
2012-05-29 18:00:05:132 [868] INFO - netborder.smartUpdate.Converter.CopyConverter : File C:\Program Files\Netborder\Express\Gateway/smart-update\tmpDir1\sip-response-isdn-cause-mapping-rfc3398.xml does not exists
2012-05-29 18:00:05:132 [868] INFO - netborder.smartUpdate.Converter.CopyConverter : Copying file winSnmpExtension.properties
2012-05-29 18:00:05:132 [868] INFO - netborder.smartUpdate.Converter.CopyConverter : File C:\Program Files\Netborder\Express\Gateway/smart-update\tmpDir1\winSnmpExtension.properties does not exists
2012-05-29 18:00:05:132 [868] INFO - netborder.smartUpdate.Converter.CopyConverter : Copying file winSnmpExtension-dev-logger.properties
2012-05-29 18:00:05:132 [868] INFO - netborder.smartUpdate.Converter.CopyConverter : File C:\Program Files\Netborder\Express\Gateway/smart-update\tmpDir1\winSnmpExtension-dev-logger.properties does not exists
2012-05-29 18:00:05:132 [868] INFO - netborder.smartUpdate.Converter.CopyConverter : Copying file winSnmpExtension-prod-logger.properties
2012-05-29 18:00:05:132 [868] INFO - netborder.smartUpdate.Converter.CopyConverter : File C:\Program Files\Netborder\Express\Gateway/smart-update\tmpDir1\winSnmpExtension-prod-logger.properties does not exists
2012-05-29 18:00:05:132 [868] INFO - netborder.smartUpdate.Converter.CopyConverter : Copying file certs/
2012-05-29 18:00:05:132 [868] INFO - netborder.smartUpdate.Converter.CopyConverter : File C:\Program Files\Netborder\Express\Gateway/smart-update\tmpDir1\certs/ does not exists
2012-05-29 18:00:05:251 [868] INFO - netborder.pbxConfigurator.PbxConverter.WanpipeSetter : Updating wanpipe to match current board configuration in pstn-config.xml
2012-05-29 18:00:05:310 [868] INFO - netborder.pbxConfigurator.PbxConverter.CopyConfig : Copying file gw.properties to C:\Program Files\Netborder\Express\Gateway\config\gw.properties
2012-05-29 18:00:05:310 [868] INFO - netborder.pbxConfigurator.PbxConverter.CopyConfig : Copying file sip-client-registration.xml to C:\Program Files\Netborder\Express\Gateway\config\sip-client-registration.xml
2012-05-29 18:00:05:312 [868] INFO - netborder.pbxConfigurator.PbxConverter.CopyConfig : Copying file routing-rules.xml to C:\Program Files\Netborder\Express\Gateway\config\routing-rules.xml
2012-05-29 18:00:05:315 [868] INFO - netborder.pbxConfigurator.PbxConverter.CopyConfig : Copying file pstn-config.xml to C:\Program Files\Netborder\Express\Gateway\config\pstn-config.xml
2012-05-29 18:00:05:406 [868] INFO - netborder.PbxConfigurator : function main returned with code = 0
Anyone can help me resolve this issue?
Thanks,
STASH
Thanks,
STASH
