Sangoma A102D Unable to make outgoing calls
Discussion in '3CX Phone System - General' started by brentrichburg, Mar 8, 2011.
  1. brentrichburg
    Nov 16, 2010
    30
    I was able to configure a Sangoma A102D with Netborder Express 4.0.
    After I learned that the authentication password had to be blank I was able to receive incoming calls!
    I am unable to make outgoing calls. I included the log for an outgoing call. The seeming trouble line is highlighted.
    14:22:23.653 [CM503008]: Call(76): Call is terminated
    14:22:18.841 Session 2183 of leg C:76.1 is confirmed
    14:22:18.638 [CM503007]: Call(76): Device joined: sip:10002@10.9.27.251:5064
    14:22:18.622 [CM503007]: Call(76): Device joined: sip:101@10.9.25.60:49582;rinstance=3abcc68fbc52207a
    14:22:18.607 [MS210007] C:76.1:Answer provided. Connection(by pass mode): 10.9.27.251:5314(5315)
    14:22:18.575 [MS210001] C:76.4:Answer received. RTP connection[unsecure]: 10.9.27.251:5314(5315)
    14:22:18.560 Remote SDP is set for legC:76.4
    14:22:18.544 [CM505002]: Gateway:[Patton 1] Device info: Device Not Identified: User Agent not matched; Capabilities:[reinvite, replaces, able-no-sdp, recvonly] UserAgent: [Patton SN4114 JO EUI 00A0BA0605A5 R5.3 2009-01-15 H323 SIP FXS FXO M5T SIP Stack/4.0.28.28] PBX contact: [sip:10002@10.9.25.82:5060]
    14:22:18.544 [CM503002]: Call(76): Alerting sip:10002@10.9.27.251:5064
    14:22:15.466 [CM503025]: Call(76): Calling PSTNline:97740146@(Ln.10002@Patton 1)@[Dev:sip:10002@10.9.27.251:5064]
    14:22:15.466 [MS210006] C:76.4:Offer provided. Connection(by pass mode): 10.9.25.60:40030(40031)
    14:22:15.450 [CM503003]: Call(76): Call to sip:8067740146@10.9.25.82:5066 has failed; Cause: 488 Not Acceptable Here; from IP:127.0.0.1:5066
    14:22:15.294 [CM503025]: Call(76): Calling Unknown:8067740146@(Ln.10010@Sangoma A102D)@[Dev:sip:10011@10.9.25.82:5066]
    14:22:15.278 [MS210002] C:76.3:Offer provided. Connection(transcoding mode): 127.0.0.1:7456(7457)
    14:22:15.263 [CM503003]: Call(76): Call to sip:8067740146@10.9.25.82:5066 has failed; Cause: 488 Not Acceptable Here; from IP:127.0.0.1:5066
    14:22:15.122 [CM503025]: Call(76): Calling Unknown:8067740146@(Ln.10010@Sangoma A102D)@[Dev:sip:10010@10.9.25.82:5066]
    14:22:15.107 [MS210002] C:76.2:Offer provided. Connection(transcoding mode): 127.0.0.1:7454(7455)
    14:22:15.091 [CM503004]: Call(76): Route 2: PSTNline:97740146@(Ln.10002@Patton 1)@[Dev:sip:10002@10.9.27.251:5064,Dev:sip:10003@10.9.27.251:5066,Dev:sip:10000@10.9.27.251:5060,Dev:sip:10001@10.9.27.251:5062]
    14:22:15.075 [CM503004]: Call(76): Route 1: Unknown:8067740146@(Ln.10010@Sangoma A102D)@[Dev:sip:10010@10.9.25.82:5066,Dev:sip:10011@10.9.25.82:5066]
    14:22:15.028 [CM503010]: Making route(s) to <sip:7740146@10.9.25.82:5060>
    14:22:15.028 [MS210000] C:76.1:Offer received. RTP connection: 10.9.25.60:40030(40031)
    14:22:15.013 Remote SDP is set for legC:76.1
    14:22:15.013 [CM505001]: Ext.101: Device info: Device Not Identified: User Agent not matched; Capabilities:[reinvite, replaces, able-no-sdp, recvonly] UserAgent: [3CXPhone 5.0.14446.0] PBX contact: [sip:101@10.9.25.82:5060]
    14:22:14.997 [CM503001]: Call(76): Incoming call from Ext.101 to <sip:7740146@10.9.25.82:5060>
    14:22:14.982 [CM500002]: Info on incoming INVITE:
    INVITE sip:7740146@10.9.25.82:5060 SIP/2.0
    Via: SIP/2.0/UDP 10.9.25.60:49582;branch=z9hG4bK-d8754z-272e2019e658fe00-1---d8754z-;rport=49582
    Max-Forwards: 70
    Contact: <sip:101@10.9.25.60:49582;rinstance=3abcc68fbc52207a>
    To: <sip:7740146@10.9.25.82:5060>
    From: "8062964071"<sip:101@10.9.25.82:5060>;tag=c83db644
    Call-ID: ZjIxYzJiMDNiYzViMzYxZmJkYjFjZGNmMDNjNWY3MjM.
    CSeq: 2 INVITE
    Allow: INVITE, ACK, CANCEL, OPTIONS, BYE, REGISTER, SUBSCRIBE, NOTIFY, REFER, INFO, MESSAGE
    Proxy-Authorization: Digest username="101",realm="3CXPhoneSystem",nonce="414d535c038720f672:f4f292685d504e02e87ec9ed299452c4",uri="sip:7740146@10.9.25.82:5060",response="b6e61fab2bdda303d4a400cfb088a210",algorithm=MD5
    Supported: replaces
    User-Agent: 3CXPhone 5.0.14446.0
    Content-Length: 0
  2. brentrichburg
    Nov 16, 2010
    30
    Additionally, I have only one T1 plugged in. The Netborder Express (NBE) "side" has 2 ports configured. 1 bank shows idle, the other shows alarmed. I have tried configuring it for just 1port in NBE. The result was the same.
    I get an unsupported media error on the 3cx softphone.
  3. Julien Nephtali
    Jun 7, 2010
    SIP 488 would indicate a codec mismatch in the sdp exchange.
    Are you trying to set up the call with another codec than G.711.
    NBE only supports G.711 u-law and G.771 a-law
