Sangoma Netborder Express T.38 Faxing works
Discussion in '3CX Phone System - General' started by dannybrook, May 23, 2011.
  1. dannybrook
    Feb 24, 2010
    43
    I got fax working over pri to the 3cx fax extension. I had to enable Re-Invites and PBX delivers audio for the gateway in 3cx. But the real issue was under advanced configuration in the NBE, the value "netborder.media.t38.supported" was set to false. Set it to "true" and I was in business.
    I could see in the NBE logs that it was rejecting the 3CX Re-invite with:
    Code:
    2011-05-22 20:09:26:357 -0700 [4740] INFO - netborder.voip.Sdp.summary : SDPMediaDesc0(Remote SDP T.38 offer is does not match local capacities, T.38 support might be disabled)
    2011-05-22 20:09:26:357 -0700 [4740] INFO - netborder.voip.Sdp.summary : Remote SDP offer is invalid because not a single media description is supported. SDP offer :
    v=0
    o=3cxPS 216912625664 417618460674 IN IP4 192.168.11.61
    s=3cxPS Audio call
    c=IN IP4 192.168.11.61
    t=0 0
    m=image 10000 udptl t38
    a=T38FaxVersion:0
    a=T38MaxBitRate:14400
    a=T38FaxRateManagement:transferredTCF
    a=T38FaxMaxBuffer:10500
    a=T38FaxMaxDatagram:1500
    a=T38FaxUdpEC:t38UDPRedundancy
    I cross checked all the other values and they were set correctly...the t.38 support was just disabled!
